Failed Emissions Again
woohooooo! 4x failed the emissions!! yes i rock! lets see whats been done
new muffler
new cat
2 bottles of seafoamman
new plugs wires
new pcv
cleaned out egr and its working ( did vac test)
timing is right
oil change
man this truck runner sooooooooo good now gas milage up lots of power for a 3.slow
im thinking it might end up with some 9mm holes
new muffler
new cat
new plugs wires
new pcv
timing is right
oil change
call your state testing centre and get them to recommend another shop. i had problems with mine, turned out the egr was non-functional. once that was changed, passed without issue.
good luck.
lee
good luck.
lee
Check your plugs and see what color they are. If they are black then you're truck is running rich.
My next suspected culprit would be water temp. sensor, not the sensor for the dash gauge. If it's busted your computer will always run rich like it's still in warm up mode.
no is high 956 is max im at 1149 plugs look great just changed state doesnt tell ya to go anywher i can do it all myself if i like EGR is working from what i can tell hooked vac line to it and engine tries to stall
the NO was high on mine and it turned out to be a combo of a plugged pcv valve and the timing being set out of wack (it had been tampered with by the shop where I went for testing [they were shut down I heard]) I'd get a different shop to check everything again if I were you...
before u go crazy, i would check the mass air flo censor, if it is the least bit dirty it would fail emission. i failed three times at that was the cause. simply cleaned with carb cleaner. good luck.
The 5w30 was running a little thin I had to add about a qrt. between changes I put in the 10w30 and it was'nt loosing as much... now that I'm running the Engine Restorer stuff at each change as well I might tyr the 5w30 again but this engine has 315K on it and the thicker oil might still be better... we'll see what happens...
The 3.0 doesn't have a MAF. If you're talking about the VAFM, what is there to clean, the swinging flap door?
wooohooo failed yet again!! and my reading is higher still 1203 956 passes
new plugs/wires
new cat and muffler
cleaned egr
tested egr with vacuum working
new pvc
oil change
this is all within 2 weeks
AGGGGGGGGGGGGGGGGGGG
what the hell is next???
new plugs/wires
new cat and muffler
cleaned egr
new pvc
oil change
do you warm it up (like a 15 mile day drive 1st)
you can add some alchohol to the fuel (or something ) to make it burn really clean. maybe the octane of fuel is too high or too poor quality.
either that, or put some holes in the top of the exhaust pipe
