Factory cab over weber carb, problems
Old 10-03-2013, 07:34 PM
Derick195's Avatar
Ok my 86 Toyota come with a webber 32/36 carb and a 2 inch spacer and every time I get on a hill or anything it try's flooding on me my air screw is alll the way in so I bought a factory carburetor and t won't bolt up without the throttle linkage hitting the intake and I can not find anyyyywhere to get a spacer to fit the factory carb any help this is temporary until I get my weber rebuilt if it's worth it
Old 10-03-2013, 07:42 PM
Toyota~Boy's Avatar
Okay... Are you saying your truck currently has a Weber on it. Correct.. Your wanting to temporally swap out the Weber for a Factory Carb right...
Under the Factory carbs there's a roughly 1/2" spacer plate thingy. If you don't have that then that's why your linkage is hitting the intake. I dunno we're you can buy that part unless you find a used one.
For aftermarket spacers you may try
Www.Lcengineering.com
Old 10-04-2013, 04:38 PM
stock87's Avatar
Factory phenolic spacer is still available from the dealer actually, and for not that much cash. The gaskets are permanently attached to it as well, so it's a much better deal than trying to make the aftermarket ones not leak.
Old 10-09-2013, 09:32 PM
Derick195's Avatar
If your out in the woods which is better is my concern is a good webber or a good factory carburetor better off I can't get my weber to quit flooding out
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Yota.Jay
07-23-2015 08:08 PM
skoti89
07-08-2015 12:05 AM
Steezy96yota
07-06-2015 10:00 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: Factory cab over weber carb, problems
