F-150 Horn Swap Help
I'm having trouble with wiring the relay. I have a four pin relay and I'm wiring it like this
85 - Battery Positive
86 - Battery Ground
30 - Horn Positive
I can hear the relay clicking so that's working but the horn won't honk. Could anyone help?
86 - Battery Ground
30 - Horn Positive
Why are you messing with a relay?? Are you running a completely Independent Horn wiring and not using any of the Toyota parts??
just hook it up to your horn wires if your using the stock horn switch
Did you make sure it works first??
your horn also needs a good ground if it is not grounded it will not work.
