Extra power
Old 02-04-2012, 04:03 PM
toda90's Avatar
Extra power
So I have a 91 extra cad sr5 4x4 with a 93 22re. I use it as a daily driver but I wouldn't mind a little bit of extra power. What's the best and most effective way to gain a little horsepower while not loseing gas mileage? A cool air intake? Or something along those lines?
Old 02-04-2012, 04:09 PM
hondacr57's Avatar
Nothing is really worth it, unless you want to do a motor swap.....
Old 02-04-2012, 04:49 PM
combatcarl's Avatar
Just regular tune-ups and normal maintenance, some guys here like a little cam, maybe a better head. And your truck comes stock with a cold air intake. Sucks outside air around the headlight. A "cold" air intake sucks hot under hood air, it just has a bigger element, so less resistance. Just love it the way it is, reliable.
Old 02-04-2012, 05:16 PM
toyota4x4907's Avatar
Smaller tires
Old 02-04-2012, 05:31 PM
rattlewagon's Avatar
Start drafting on the highway.
Often times, the best way to get better MPGs is to change your driving habits. Less skinny pedal, more MPGs.
Check out these guys.. they make lots of go fast parts.
Old 02-04-2012, 05:44 PM
donomite49's Avatar
header and 2.5 exh helped my 22re.
Old 02-05-2012, 12:10 PM
exist's Avatar
270/430 cam from engnbldr likes when you rev the truck hard.. I wouldn't say anything that was done to my motor has made it roast the tires.. it just has more power through the rpm range and I don't need to down shift anymore..
engnbldr head, cam, larger valves, lce header, egr block off plates, cone filter in the engine bay, 10.0:1 compression ratio, 2.25" exhaust with no resonator/cat/etc..
I wouldn't recommend anyone build a 22re ... just go 3rz swap with some mild bolt ons and call it a day. Before everything I got 22mpg pretty reliably, now I'm at 19 or so.. Leave the 22re alone and enjoy it not giving you grief.
Old 02-05-2012, 12:13 PM
bobby_duce's Avatar
my first question is what tire size and gears you have.
Old 02-05-2012, 12:20 PM
nightstalker's Avatar
31. 10.50/4.56
Old 02-05-2012, 12:34 PM
bobby_duce's Avatar
if thats the case hes running the proper tire/gear combo. id start with a full tune up and full exhaust setup. my .02 cents
Old 02-05-2012, 12:40 PM
sixstringslut's Avatar
5th gear is a waste until 65 mph, if you can do that? Maybe 235's?
My 88 has 31's and kicks OK but my 94...there is no way. Both are 22re's 4X4's.
Old 02-05-2012, 12:50 PM
skypilot's Avatar
Like he said:
You could change to a really slick synthetic engine oil, adjust the valves to spec. Change the trans fluids to a modern synthetic as well, and change all the filters. change to a larger ignition coil & do a full tune up.
After that it starts to get expensive, headers, overbore TB, CD Ignition, camshaft, chain & guides, head work (LCE ? 22RE Performance).
coleypull15
11-03-2015 07:41 AM
RatOmeter
10-22-2015 03:17 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
TDonkey
07-26-2015 10:14 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: Extra power
