exhaust through rear window
Old 09-14-2008, 01:52 PM
88T4R's Avatar
I put a new full exhaust on my 88 4runner about a month and a half ago and I am still getting exhaust through the rear window when it is down and now I never have it down anymore. The old exhaust did this too and I thought it was a leak in the pipe, but it still seems to come in when the rear window is down. The pipe comes out right behind the drivers side rear tire. I tightened all bolts on the flanges and the rest is fully welded up, anyone have any ideas or is anyone else having this problem? Thanks!
Old 09-14-2008, 02:04 PM
Staff
DeathCougar's Avatar
They all do it. Its why toyota added a rear wind deflector to the 90+ 4Runners.
Old 09-14-2008, 02:06 PM
BMC
BMC's Avatar
Yep. The only other solution to that is leave your window up or get use to the smell.
Old 09-14-2008, 02:09 PM
4Crawler's Avatar
Try experimenting with how far you lower the window. On my '85, I found how far I could open the glass before pulling in exhaust on the road. Usually could get it down a few inches and it was OK. And add a wind deflector in back, will also help keep dust and snow off the rear window as well:
Old 09-14-2008, 02:16 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Also cracking the sliding windows open a bit helps.
Old 09-14-2008, 02:21 PM
Matt16's Avatar
I think the only real solution is the wind deflector.
Old 09-14-2008, 02:23 PM
88T4R's Avatar
ok thanks guys i thought maybe it was just me, that makes me feel a whole lot better knowing everyone else has this problem too!
Old 09-14-2008, 02:24 PM
88T4R's Avatar
I was thinking about trying to point the exhaust down or move it up in front of the rear tires, just an idea has anyone else tried this with good results!
Old 09-14-2008, 03:14 PM
rhale's Avatar
lol!! my wife hates this! we just had this discussion during our last drive. by the time we were done she had a headache from the fumes. i thought about cutting the exhaust off right behind the muffler to see if that kept it "below" the window level, but didn't know if that would work.
Old 09-14-2008, 03:39 PM
AndYota's Avatar
I have mine cut just after the axle and still get a bit if I'm driving below 25mph and I have the rear deflector on mine. I've noticed that having the rear windows cracked helps, and only rolling down the back 4 or 5 inches.
Andy
Old 09-14-2008, 04:08 PM
kipres's Avatar
cutting it off there only makes it worse
Old 09-14-2008, 04:09 PM
Targetnut's Avatar
Getting use to the smell is not an option.
Carbon Monoxide is completely odorless and builds up in your system over time. It requires more time to get out of your system.
so if you cansmell exhaust, you need to correct that right away.
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
tj884Rdlx
08-28-2015 12:04 PM
icentropy
07-14-2015 10:23 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: exhaust through rear window
