Exhaust pipe hanger? Or shipping clamp?
Old 04-05-2011, 02:17 AM
MAD MARK's Avatar
So I am replacing the whole exhaust from manifold crossovers back on a 1991 3.0. In the process I bought most stuff off of RockAuto at great prices.
I received the first piece of pipe that bolts to the crossovers and it came with a "clamp" on the pipe. I looked under truck and the old pipe didnt have this anywhere. Was thinking it could be a hanger clamp.
I dont have a picture of the "clamp" but the intermediate pipe has the same thing but with a bolt through it. I was thinking maybe its a shipping/hanging thing they do in the warehouse. Any insight?
WALKER Part # 43204 Front Pipe
Anyone know offhand what the center to center dimension of the 02 gasket is on a 91 3.0?
Also I found out the Xtra cab front to back parking brake cable is dealer only. No one has it as I can see.
Old 04-05-2011, 05:29 PM
animalslayer's Avatar
you should be able to find the cable at advanced auto, thats where i found it.
Old 04-05-2011, 07:57 PM
MAD MARK's Avatar
Well. If you happen to have the part number handy I would like that.
I took apart the whole rear brakes/parking brake. Cleaned everything up with wire wheel/sand paper and steel wool. Lubed everything back up when putting back together. Saved $76 in parts I returned just lubing and cleaning everything back up. Replaced the leaking right wheel cylinder while I was in there as well. Wish they were all as easy as this one was. Rusty as hell, but everything came right off.
I would like to replace the bracket though that is the center and hooking piece for the front to rear parking brake cables. Im going to do some research to find it but anyone know where to get that offhand?
By the way the O2 sensor is 1.75" CTC.
Old 04-05-2011, 07:59 PM
MAD MARK's Avatar
And the reason I was wondering the CTC is because I made a block off plate tonight at work for the 02 sensor while I run some seafoam through the engine. I have heard that sometimes it messes with the sensor and other times it doesnt. Im just going to take it out of there for good measure.
Old 04-06-2011, 03:15 AM
sure ill look at the packaging when i get home from work
nvdesertrunner
05-11-2020 08:18 PM
Jcrawl94
10
10-24-2015 04:34 PM
94 Newbie
08-06-2015 10:33 AM
hexrain
07-12-2015 01:13 PM
Quick Reply: Exhaust pipe hanger? Or shipping clamp?
