Exhaust manifold studs and Helicoils
Old 06-03-2013, 11:17 AM
etont's Avatar
two of the exhaust manifold studs on my 22re 86 4runner are stripped out. I did some research on the forums and it seems that I can use Helicoils instead of retapping to a larger size. I also saw that they are 8x1.25? Coarse or fine thread?
Any idea where I can get the helicoils?
Thanks,
Eton
Old 06-03-2013, 12:39 PM
etont's Avatar
Never mind, found it =)
Old 06-03-2013, 12:56 PM
scope103's Avatar
Just about anywhere.
Helicoil 5546-8 M8 x 1.25 Metric Coarse Thread Repair Kit : Amazon.com : Automotive Helicoil 5546-8 M8 x 1.25 Metric Coarse Thread Repair Kit : Amazon.com : Automotive
http://shop.advanceautoparts.com/web...hTerm=helicoil
Don't forget the 21/64" bit.
Old 06-03-2013, 01:01 PM
etont's Avatar
Is it m8x1.25? Ive been reading m10x1.25
http://www.lceperformance.com/Header...-p/1045030.htm
http://board.marlincrawler.com/index.php?topic=56140.0
Old 06-03-2013, 01:04 PM
wyoming9's Avatar
Red face
I hate to rain on your parade !!
The thread size is M10x 1.25
The 1.25 is the thread pitch
Helicoil is just a brand name of the first thread repair inserts .
Many more out there now .
If your local autoparts does not stock them they should be able to order them in.
Most all industrial suppliers have or can get them
you need the drill bit and the correct tap to tap your hole for the insert.
most often can come with the kit
Old 06-03-2013, 01:08 PM
etont's Avatar
Thanks! Is it coarse thread or fine thread?
Old 06-03-2013, 01:31 PM
Grego92's Avatar
Did this not too long ago. This is a picture of my kit.
Looks like the label says 5543-10 which would make it the Helicoil 5543-10 M10 x 1.25 Metric Fine Thread Repair Kit
Helicoil 5543-10 M10 x 1.25 Metric Fine Thread Repair Kit - Amazon.com Helicoil 5543-10 M10 x 1.25 Metric Fine Thread Repair Kit - Amazon.com
Old 06-03-2013, 04:07 PM
slo6i's Avatar
There isnt really a coarse or fine with metric. It gives you the thread pitch (1.20mm, 1.5mm, etc.), which is all the information you need to know... with the exception of length, but that has nothing to do with the threads, where as the UNC and UNF threads (our stupid thread system) counts the amount of threads per inch.
Scratch that. I had never heard it called coarse or fine. Just match up the bolt size and pitch to what the helicoil inner size and pitch is, drill the required hole to the size specified by the helicoil kit, thread it, then youll be good to go.
Streetrod19772000
09-10-2015 06:22 PM
Obmi
09-10-2015 03:36 AM
idadan208
09-07-2015 09:06 AM
May-39
09-06-2015 01:05 PM
Quick Reply: Exhaust manifold studs and Helicoils
