Exhaust manifold leak
Old 01-30-2011, 01:09 PM
YODAIII's Avatar
Anyone know how difficult the nuts and bolts are to remove on the exhaust manifold. I attempted to replace the bolts holding the heatshield on and two of them sheared.
Old 01-30-2011, 01:15 PM
toyota4x4907's Avatar
Spray penetrating oil on them for a few days before you attempt to loosen them. They WILL be rusted, heat warped, etc.
Make sure you have the correct size socket in good condition. It would be wise to replace them while they are out.
Old 01-30-2011, 02:07 PM
scope103's Avatar
The nuts on the manifold itself (not the heat-shield) are one-time-use, so they should definitely be replaced. I got them from my dealership, and they are not expensive. Do NOT try to use nylock nuts or regular nuts; you will not be happy with the result.
Old 01-31-2011, 08:12 PM
YODAIII's Avatar
Thanks for the info guys. I sprayed them with pb for a couple of days and loosened them today with ease. Actually, upon loosening them I found out that they were already loose so I tightened them all down temporarily. After I get new hardware I'll change the gaskets. Sure did quiet my truck down a lot.
Old 01-31-2011, 08:35 PM
SoCal4Running's Avatar
Put copper anti-seize on the new bolts/studs. It makes life so much easier!
tj884Rdlx
08-28-2015 12:04 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Exhaust manifold leak
