Exhaust leak? Or bigger problem?
Old 04-11-2010, 03:35 PM
Jaino240's Avatar
So I was driving to Vallejo today in the rain and everything was fine. In the slow lane cruising at 65 mph. A little hill came up and I had to downshift to make it over the hill, after I went over I realized the truck was making a really wired noise. Sounded like a very big exhaust leak. Exit to the nearest Chevron, checked it, there was a small leak, but it was there from before. I drove down the street to realize I have NO power at all. Had to rev the engine to make it go. Drove back to Chevron, parked it, and the truck dies. Wouldnt idle. I started it back up, but still it wouldnt idle. I had to keep my foot on the gas. It was stilll driveable. Drove it back home, but with no power at all. Truck starts but wont idle, and there is a big exhaust leak sound.
I'm going to go check on it right now, but I wanted to know if an exhaust leak would cause my truck to act this way. Or is it something else?
1989 4 cylinder 22re
Thanks in advance
Old 04-11-2010, 04:31 PM
ahickman's Avatar
A huge exhaust leak would cause a noticeable loss of power, but that same leak would be easy to find. Did you check along the exhaust manifod or even the spark plugs? I bought an 87 runner last month and had similar problems driving it home. Pulled over and found that #1 plug was loose and was in by only a thread or two.
Old 04-11-2010, 04:53 PM
Jaino240's Avatar
I just did. Checked everything. havent checked the spark plugs, but I will. its pretty loud, I'm thinking it may be a rod knock now.
Never had this happen, but if the engine was knocking would I still be able to drive it? Idle?
Old 04-11-2010, 05:08 PM
GranVille-4crawler's Avatar
Yeah it would run intil you shoot a rod out the block.... happened to me going 130 on my gsxr
Old 04-11-2010, 05:11 PM
Jaino240's Avatar
So yeah turns out, its a rod knock. sucks pretty bad considering I just sold my 240sx to fund the SAS for this truck.
Old 04-11-2010, 05:16 PM
Don't get too down. Just buy a rebuild kit
Old 04-11-2010, 08:24 PM
Jaino240's Avatar
Thanks man. Yep, just been looking at LC engineering's kits. Do you know anyone else that sells a cheaper rebuild kit?
Old 04-11-2010, 09:38 PM
Philbert's Avatar
Sorry to hear. LC has good stuff but can get pricey and it sounds like you're on a budget. Have you looked here:
http://engnbldr.com/
Old 04-12-2010, 03:54 PM
Jaino240's Avatar
No, but I will definitely check that out. Yes, I am on a budget. College+rent+4wheeling doesnt really get along so good. lol But hey I will get it done though.
The good thing is my rod didnt shoot out of the block. But I am wondering if I should get a new engine because it was knocking for awhile. I'd say an hour? Drove from Vallejo to Sacramento and parked it at my grandmas place.
Old 04-12-2010, 04:10 PM
pruney81's Avatar
since you're in Northern California, check these guys out for a new engine, they're in Chico, I believe.
http://www.putneyscustommachine.com/...20Machine.html
Old 04-12-2010, 08:13 PM
Jaino240's Avatar
Thanks for the info. I live pretty close to TAP in Rancho Cordova and Attarco is only a couple hours away in Richmond.
I only need a bottom block though or should I get a whole new engine
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
hexrain
07-12-2015 01:13 PM
Coreyr384
07-10-2015 11:13 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Exhaust leak? Or bigger problem?
