Exhaust for 550 bucks????
Old 11-05-2008, 11:31 AM
AZ89LONGBED's Avatar
I just got quotes from several places in town to replace my cat, muffler & tailpipe for between 500-550...
I just priced a pacesetter cat-back & replacement cat for around 320 shipped. Does anyone have a better idea? Have any of you guys heard of prices that high?? The bends at both shops are not mandrel bent, eith, if that matters, but the pacesetter is.
I really do not need a loud ricer exhaust, just a new one.... Ugh...
Old 11-05-2008, 11:34 AM
Hayes's Avatar
I paid 300 for mine to be bent from the cat back... Labor is expensive. 500-550 sounds reasonable from the headers back.
Hayes's Avatar
Oh and Mandrel is expensive and not needed really.
Old 11-05-2008, 11:48 AM
Just got off the phone with the dealer, Toyota no longer stocks the factory replacement cat-back, which would have only cost 142.something....
There should be a cheaper alternative, both places quoted between 200-250 for the cat. I am looking at a direct-fit replacement from Summit for 91... I asked if I brought in an aftermarket cat & cat-back, what the install would be, and they both say between 300-400 bucks.
I would like to support local biz, but f-these guys! I can install a direct-fit cat & cat-back by myself with regular tools, right? My header is brand new so I need not worry about crusty bolts...
Old 11-05-2008, 11:50 AM
Hayes's Avatar
Then why don't you? If you can and don't want to fork out the cash, just buy the parts and do the install.
Old 11-05-2008, 11:51 AM
scuba's Avatar
you can DIY as long as it doesnt need to be welded...
Old 11-05-2008, 11:52 AM
904_runner's Avatar
what if he has a welder?????
Old 11-05-2008, 11:56 AM
chrisbnaz's Avatar
Thats a rediculous amount of money IMO.
Old 11-05-2008, 02:29 PM
Noltz's Avatar
Pacesetter is garbage. At least the one I bought for my Dodge sucked. Rusted out in 2 years. And the Pacesetter does NOT come with a cat. You say the local guys are including the cat @ $500. Factor in the installation (and could could say the labour to build it) and the prices come a lot closer.
That said, it's still too much. Local shop here does most cat-backs for ~$300 CDN, or $400 w/a cat.
Old 11-05-2008, 02:38 PM
olharleyman's Avatar
X2
You can go to the local napa ,pep boys ,autozone ,schucks whatever you have local and get a universal cat and muffler plus exhaust pipe needed to do it and then get the exhaust bolt on U clamps to hold it in place till you can find someone to weld them together if you can't weld them yourself and save yourself 300 plus bucks
Old 11-05-2008, 02:45 PM
space-junk's Avatar
rediculous... you could get a high flow cat, or even go as i did and get a mid 90's chevy half ton cat installed...
mine with cat, piping, magnaflow muffler, piping, chome tip was only 300...
Old 11-05-2008, 02:46 PM
rusche's Avatar
I went to the Flowmaster here in Hayden, ID
Paid $350, from my LC header back to a resignator and a 40 series.
Great work.
Old 11-05-2008, 02:55 PM
91slowrunner's Avatar
DIY job for around $200
Old 11-05-2008, 03:07 PM
Trustyrusty's Avatar
DO NOT get the Pacesetter header, Had one, It rusted out.. Get yourself two sticks of 2.25" exhaust pipe for about 20$ from summit, a 20$ cherry bomb turbo muffler that is also 2.25" and has offset inlet and outlets, weld the pipe to your header/manifold and then cut it, turn the muffler on its side so the exit is higher then the rear axle, and run it straight out the back with an echo tip. Sounds good, you could also use a offset in/out glasspack.. my whole exhaust cost me 45$, and I have a dynomax turbo muffler, 2.25" pipe, and a turn down..
Old 11-05-2008, 07:02 PM
Greyhorn's Avatar
I had a 2.5" (22ret) made up and installed at a local shop for $240.00 w/o cat.
Old 11-05-2008, 07:17 PM
Staff
DeathCougar's Avatar
Funny, i can still get the factory exhaust at my local dealer...
Old 11-05-2008, 07:41 PM
anotherjeff's Avatar
Anybody know if the dealer still offers the lifetime warranty on installed exhaust systems (and struts/shocks)?
Old 11-06-2008, 12:36 AM
ovrrdrive's Avatar
I also had a system custom bent and welded on for less than $200 here including the muffler and chrome tip.
I'd say look around or do it yourself. That's robbery for a crappy pressure bent system.
Old 11-06-2008, 04:12 AM
frisbeedog's Avatar
I just got a high flow cat, dynomax muffler, and 2" pipe all the way back for $300.00. They forgot to throw in bling tail pipe though!
Old 11-06-2008, 04:29 AM
934rnr's Avatar
I think I paid $125 to have my exhaust put together on my 82 truck.
$50 for a universal cat and $25 for a muffler.
So all together around $200. I couldn't imagine $500 what are they smoking?
Quick Reply: Exhaust for 550 bucks????
