Exhaust!!
Old 12-13-2009, 02:27 AM
808Yodi's Avatar
Exhaust!!
Anyone ever run into any problems running a 2 1/2 straight pipe?
I'm thinking about running straight pipes into a 2 1/2 inlet cherry bomb extreme with two 2 1/4 outlets.
I've got some hesitation though dealing with pressure issues and using such a large pipe...what could I be getting myself into on the downside??
Thanks
Old 12-13-2009, 02:29 AM
808Yodi's Avatar
22re 4litr standard sr5 efi
Old 12-13-2009, 02:54 AM
toyota4x4907's Avatar
Your 22re has 4.0L of displacement?!
Old 12-13-2009, 08:19 AM
808Yodi's Avatar
wow, i had a lot mixing in my head haha -- i'm trying to figure out how a 4.0 got on there??
ohhhhh, 4 cylinder...
thanks
Old 12-13-2009, 08:21 AM
808Yodi's Avatar
pretty sure i'm gonna run 2.5" straight pipe into a 2.5 in/out cherry bomb extreme exhaust -- finishing out with an edelbrock or flowmaster turn-down tips.
Should be rediculous!!
Old 12-13-2009, 08:29 AM
zachw90's Avatar
2.25
Old 12-13-2009, 08:54 AM
808Yodi's Avatar
That's what i was thinking but i figured that if i kept the headers stock I should be cherry in low gears -- that should give it enough back pressure...
You still think that opening it up beyond 2.25 is gonna drop my torque noticeably? I don't think that'd be worth it at all...how about in 4L and 4H...gotta keep the off-road solid...
Old 12-13-2009, 09:21 AM
1990yota-pickup's Avatar
putting a big pipe on there is not different thant putting a big fart can exhuast on a honda civic.. or so it just makes alot bee hive nosie and actually drops the horse power.
Old 12-13-2009, 09:41 AM
kawasakimoto_7's Avatar
you wont loose thaatttt much but youll notice it a little bit, and youll run more healthy on the freeway with that kind of diameter. i say do it and see if you like it...
Old 12-13-2009, 09:54 AM
if i were you i would put one of those fart can exhuast on.. i have yet to see on one a toyota truck. That is creeping out from under the rear bumper
Old 12-13-2009, 10:02 AM
myyota's Avatar
2.5 is to big and your going to loose some bottom end power unless you have a cam and a performance head with over sized valves. Go with a 2.25 exhaust if you engine is mostly stock, you will see a noticable gain.
Steven.m.paulk
06-07-2020 10:45 AM
the_supernerd
10-01-2015 09:20 PM
voiddweller
09-28-2015 11:21 PM
Keithstoyota
09-27-2015 07:29 AM
Quick Reply: Exhaust!!
