exhaust
exhaust
has anybody ever used this type of muffler i was thinking of cutting down the ends and running dual exhaust right before the tires.
wat size tubeing should i run i have a 3.4l and i was was thinking about running 2.5 inch dont know if thats to big thanks.
You should be able to use that muffler and run the pipes like you want to but if the pipes coming out are 2.5" or bigger you may lose low end torque but you should see an increase in the upper end.
Have you heard what this muffler sounds like?
Your best bet would be to just get a single 2.5" inlet and a single 2.5" outlet muffler that flows really well.
i still have the 3.0 exhaust on the veichle so i should gain some performance. its a glass pack designed muffler so its goin to flow great. also ive thought about blocking one of the tubes which i dont think will matter.
yea ive got endless posibilties with this setup cause i have to go and get the system completly custom. so if anybodys got some ideas let me know thanks.
I had a flowmaster 40 series and 2.5 duals ran out the corners on my '90 3.0. It was one in and two out just like what you have there. Sounded great. You will like it.
oh yea ill go and run my exhaust right out the hood itll be kool and give me like 100 more hp just like red stickers and muffler bearings. do you have any pics of your exhaust thanks.
pipe size in the headers (manifolds) is relevent to torque. you should lose some backpressure if it's an aftermarket muffler, but that might give it an unnoticable amount of top end. if it's too loud, it'll sound like ▓▓▓▓ (v6's fault)
