Excessive Heat from Gear Box / Transfer Case
Old 06-10-2014, 01:28 PM
Mdcollins3's Avatar
Hey there everybody. I've scoped out the site for years, and just finally registered. I'm having (what I believe is) an issue with my 93 22re pickup. I removed the cab carpet in fall (when it was cool). In the past few months as it has gotten hotter outside I have noticed the floor in the cab around the gear box / transfer case has gets very hot, only after 5 or so miles. I know that there will certainly be heat radiating into the cab, but this seems too hot. I've changed the fluids in both gear & trans with no difference. Suggestions? Ideas? Thanks for your help.
Old 06-10-2014, 02:33 PM
wyoming9's Avatar
Red face
Don`t forget your cat sits just about under the drivers seat heat always goes up
80 or 90 degree temps don`t help.
Old 06-10-2014, 04:06 PM
JasonYota's Avatar
You also have heat coming from the exhaust up under the truck. Reinstall the carpet and add insulation.
Old 06-10-2014, 05:29 PM
rattlewagon's Avatar
Put your carpet back.
No strange noises? Seems normal to me.
Old 06-10-2014, 06:54 PM
jbtvt's Avatar
You can look into Lizardskin roll on insulating liner as well, I will probably go that route soon.
Old 06-10-2014, 07:04 PM
RJR
RJR's Avatar
Also keep in mind that what's hot to you isn't particularly hot to steel and oil. It's common for the oil in your transmission and rear end to run upwards of 130-150 degF, and short-term it can go well past 200 during a heavy pull without hurting anything. Some heating is good in that it causes the condensed water in the gear boxes to vaporize and get out of there.
Yotadawgjr
10
08-23-2015 10:51 AM
Tykiller1994
08-10-2015 07:49 PM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
Poncho0206
07-10-2015 06:21 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Excessive Heat from Gear Box / Transfer Case
