enough clearance to replace rear wheel stud without pulling axle from backing plate?
Old 11-03-2009, 12:07 PM
wilshire's Avatar
I've got a rear wheel stud that has buggered threads. Can I replace it without pulling the axle shaft from the backing plate?
Update: Replaced wheel stud last weekend. Plenty of room.
Old 11-03-2009, 01:26 PM
Elton's Avatar
should be enough room i just did one on my 4runner took the drum off gave it a hard smack with the BFH popped right out
Old 11-03-2009, 02:20 PM
iamsuperbleeder's Avatar
just barely, but yeah Toyota gave us enough room luckily to be able to replace the studs without haveing to have the axle shaft pressed of the backing plate but it might be easier too if you remove all the brake hardware crap out of the way...
voiddweller
19
05-02-2016 09:10 PM
merc1100sc
06-26-2015 05:24 PM
cchinny
06-25-2015 08:11 PM
Mr.Black
06-21-2015 10:17 AM
Luke
06-10-2002 10:07 AM
Quick Reply: enough clearance to replace rear wheel stud without pulling axle from backing plate?
