Engine won't stay running - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-03-2007, 01:34 PM   #1 (permalink)
89truck's Avatar
I just finished the air intake / battery swap on my 89 22RE. I went to start it, it starts but dies after a second or two. I did a search but none of the ones I found really helped. Any help would greatly be appreciated.
__________________
89 Truck, 4X4, 22RE, LCE Header, 2.25" Exhaust with Magnaflow cat & muffler, Battery/Intake swap, 32X11.50 Pirelli Scorpion A/T's, 15X8 Cragar Streetlock
89truck is offline
Old 04-03-2007, 01:40 PM   #2 (permalink)
rdharper's Avatar
Quote:
Not an expert here, but what comes to mind is... how did you make sure the AFM continues to report the correct air gate position.. or the equivelant?
__________________
Richard
"Science by consensus... is not Science." Richard Harper -1988
'94 Toyota 4Runner V6 3L 158K miles 14mpg
'85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg
'08 Honda Ridgeline RT 2.6K miles 16mpg
'06 Honda Rincon ATV 410miles/65hrs 22 mpg
rdharper is offline
Old 04-03-2007, 01:53 PM   #3 (permalink)
89truck's Avatar
Quote:
I rerouted the wires that ran along the drivers side. I took them out of the the plastic sheath and routed them around the firewall down the passenger side. I never had to disconnect them.
__________________
89truck is offline
Old 04-03-2007, 02:18 PM   #4 (permalink)
rdharper's Avatar
Ok, so what you are saying is that you made no changes to the air gate system, electrically etc...
And you only changed the air feed before that air gate, as well as the battery setup.
So if that is correct, and you did not have this problem before you made the changes... you certainly should not have a "new" symptom.
What you describe sounds like lack of air/fuel correct setting while cold. But nothing you did should alter that... so it is a puzzle.
__________________
Richard
rdharper is offline
Old 04-03-2007, 02:28 PM   #5 (permalink)
89truck's Avatar
Sweet...thanks. The truck sat for four days while I was at work and waiting on an air flow meter adapter. While it sat it didn't have an air filter on it but the hood was closed. It did rain, could that have anything to do with it? Also I sprayed some throttle body cleaner on the throttle body. Started it and it ran until the cleaner burned off, if this helps anyone.
__________________
89truck is offline
Old 04-03-2007, 02:31 PM   #6 (permalink)
4runnerx3's Avatar
There are some ground wires on the intake where it comes apart.
4runnerx3 is offline
Old 04-03-2007, 02:45 PM   #7 (permalink)
rdharper's Avatar
The rain with a closed hood, for just a few days... no effect.
Throttle body cleaner... depends on what type and where you sprayed it.. probably not the cause.. but maybe.
The AFM adaptor. How sure are you that it is a correct adaptor, and that it was connected properly. If the AFM wasn't working correctly, because of electrical connections, that would do it.
I'd probably do the FSM checks on the AFM at this point.
__________________
Richard
rdharper is offline
Old 04-03-2007, 03:08 PM   #8 (permalink)
89truck's Avatar
Quote:
Which wires you speak of?
__________________
89truck is offline
Old 04-03-2007, 03:15 PM   #9 (permalink)
89truck's Avatar
Used CRC throttle body cleaner. Used it on other vehicles with no proplems. The AFM adaptor is from Spectre they make air intake products for all kinds of vehicles. The packaging stated it it would work for a Celica and the bolt holes matched. It fit well with the plastic plate that came with it. I put it on myself about an hour before this thread.
__________________
89truck is offline
Old 04-03-2007, 03:30 PM   #10 (permalink)
rdharper's Avatar
Unless you got the cleaner in the TPS, I really doubt that is the problem.
I'm still suspicious of the AFM not working correctly. But as I said, I'm not familiar with the specific changes you made... could be that others are and we need a bit of time for them to jump in.
__________________
Richard
rdharper is offline
Old 04-03-2007, 03:46 PM   #11 (permalink)
89truck's Avatar
If I knew how to post a link I would..... wait you'll see a thread for 22RE intake/ battery swap pop up. Thats what I did.
__________________
89truck is offline
Old 04-03-2007, 04:58 PM   #12 (permalink)
89truck's Avatar
Could it be electrical? TPS?
__________________
89truck is offline
Old 04-03-2007, 05:22 PM   #13 (permalink)
Flash319's Avatar
Your AFM is not working. Posible wire damage from the move, or when you plugged it in pins got damaged. What you are describing is what happends when you have no flap movement/airflow through the AFM.
Flash319 is offline
Old 04-04-2007, 03:05 PM   #14 (permalink)
89truck's Avatar
Update... I checked the AFM with an OHM meter. On the E2-VS it should read 20-400. Mine was reading from 576-586. Bad AFM? Everything else checked out. E2-VC should be 100-300 read 180, E2-VB should be 200-400 read 280, E2 Tha should be 2K-3K read 2.40 on the 20K setting, so that is 2400 right? Anyway time for a new AFM?
__________________
89truck is offline
Old 04-04-2007, 03:16 PM   #15 (permalink)
JEBSR5's Avatar
Probably so if reading off that much, but did you check for sure if AFM flap moves freely, not stuck open or is shut all the way. New flange or mount not holding open?
__________________
90 4R SR5 4WD 5SPD
3VZE
211K miles
'69 Ford Mustang Mach I
'82 Suzuki GS1100E
'68 Chevelle SS396
'99 1/2 Pathfinder LE
JEBSR5 is offline
Old 04-04-2007, 03:22 PM   #16 (permalink)
89truck's Avatar
Quote:
Flap opens and closes freely. No, the flange is not in the way. The mount currently is not connected could the have anything to do with it?
__________________
89truck is offline
Old 04-04-2007, 03:26 PM   #17 (permalink)
4runnerx3's Avatar
Did you check it fully open and closed?
Old 04-04-2007, 03:26 PM   #18 (permalink)
JEBSR5's Avatar
Only if it was a ground, which I don't think so. Know anyone you can use their working AFM and swap for a test?
__________________
90 4R SR5 4WD 5SPD
3VZE
211K miles
'82 Suzuki GS1100E
'68 Chevelle SS396
JEBSR5 is offline
Old 04-04-2007, 03:30 PM   #19 (permalink)
4runnerx3's Avatar
Old 04-04-2007, 03:34 PM   #20 (permalink)
JEBSR5's Avatar
I assumed he was measuring closed meaning his reading was off for that, but you are right about checking open and closed.
__________________
90 4R SR5 4WD 5SPD
3VZE
211K miles
'82 Suzuki GS1100E
'68 Chevelle SS396
JEBSR5 is offline
Old 04-04-2007, 03:50 PM   #21 (permalink)
89truck's Avatar
Yes. The readings were what they should be.
__________________
89truck is offline
Old 04-04-2007, 03:52 PM   #22 (permalink)
89truck's Avatar
Yes for the 1st set of reading I posted the flap was closed.
__________________
89truck is offline
Old 04-04-2007, 03:57 PM   #23 (permalink)
89truck's Avatar
AFM from Toyota $689.00. AFM for Autozone $179.99 HUH.... What the hell. Is it you get what you pay for. I called Toyota he said buy the one from the Zone. Make sure it has a full refund warranty. If it dosen't work or dosn't work long take it back then call them.
__________________
89truck is offline
Old 04-04-2007, 04:01 PM   #24 (permalink)
JEBSR5's Avatar
ok, so the readings fall within range? If so, then it's OK. If not, then go for the cheapie or try a buddies working as a for sure test.
__________________
90 4R SR5 4WD 5SPD
3VZE
211K miles
'82 Suzuki GS1100E
'68 Chevelle SS396
JEBSR5 is offline
Old 04-04-2007, 04:10 PM   #25 (permalink)
89truck's Avatar
Sorry the E2-VS with the flap closed read 576-586. Should have read 20-400.
The open flap readings were correct.
__________________
89truck is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Doesn't Stay running??? 943kgt 86-95 Trucks & 4Runners 7 02-04-2007 04:33 PM
3.4L swap wont stay running need HELP!! node 95.5-2004 Tacomas & 96-2002 4Runners 17 03-10-2005 11:45 AM
help my truck wont STAY running sniper95688 95.5-2004 Tacomas & 96-2002 4Runners 10 02-23-2005 03:17 PM
yota wont stay running Mudfreak 95.5-2004 Tacomas & 96-2002 4Runners 4 09-08-2004 07:22 AM
2009 InternetBrands, Inc.
