engine vibration..??
does it do it in nuetral? if so, maybe your clutch? i mean i guess a piece of your disc could have come off and now its out of balance? or you have a bad motor mount?..... just some ideas!
thanks for the ideas. I pretty sure its not a misfire. Its an auto so no clutch and the when I stick a pry bar in between the mounts and the frame, it vibrations even more. So im not sure what that means. As far as the crank damper... I dont know but how could I check>???
All of those wont matter since it vibrates in park when the truck is not moving. One new thing I noticed is that around 1700 rpms the truck vibrates in delayed intervals. For example, it will vibrates very slightly for a second, then nothing for a second, then back to vibrating for a second and so on. It still vibrates around 2400- 2700 rpms as well. I mean... It has to be engine related and i dont know what engine part it could be since they are all new. Actually I did break an injector wire inside the plug so I just wired the injector up without the plug. It seemed to work fine, but maybe its causing some interference or resistance issues??
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
