Engine Trouble Code (14) - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 11-20-2007, 08:59 PM   #1
az4x4runner's Avatar
Question Engine Trouble Code (14)
I jumpered my diagnostic terminals today and my check engine light flashed a two-digit code 14 (x..xxxx).
Code 14: IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
From what I understand there is a lack of Ignition Feedback to the ECU.
Does anybody know what might cause this or how to diagnose what may be causing it?
Thanks,
Bryan
az4x4runner is offline   Reply With Quote
Old 11-21-2007, 05:51 PM   #2
ah well, I figure.. hey, the thing always starts and doesn't stop 'til I want it to... can't be too bad, eh?
Old 11-22-2007, 11:16 AM   #3
881stGenRunner's Avatar
bump, i need help with this too...
881stGenRunner is offline   Reply With Quote
Old 11-30-2007, 04:12 PM   #4
Old 11-30-2007, 04:58 PM   #5
MudHippy's Avatar
You may need to replace your ignitor coil.
See page EG2-195 from the FSM troubleshoot section here. It tells you step-by-step how to determine exactly where the problem is using a voltmeter.
MudHippy is offline   Reply With Quote
Old 11-30-2007, 07:34 PM   #6
Targetnut's Avatar
IGF (I Got Fire) is the ignition comfirmation signal from the igniter to the ECM
If the IGF signal is lost for 6 ignition firing events (3 revolutions)The ECM shuts off the injectors.
My suggestion would be to clear the codes, then drive around and see if they come back.
Targetnut is offline   Reply With Quote
Old 11-30-2007, 08:20 PM   #7
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
This I have recently found to be a neat method to have under the toolbelt. It's like taking an accupuncture reading on the system. "Pin pointing" the problem.
thook is offline   Reply With Quote
Old 07-25-2009, 05:20 PM   #8
im getting the same code. i have a 95 4runner 3vze. it sat for a long tiime after headgaskets went out twice. just put a new motor in it and its running like a turd. poor throttle response and barely makes it up a small hill. 14 is the only code im getting, can anyone make any suggestions. also how would i clear the codes?
dj darkfader is offline   Reply With Quote
Old 07-25-2009, 05:33 PM   #9
toyota4x4907's Avatar
Did you replace the ignition coil(s)? To clear codes either pull the EFI fuse or disconnect the battery for like 30 seconds.
toyota4x4907 is offline   Reply With Quote
Old 07-26-2009, 09:39 PM   #10
CC_yota's Avatar
I'm encountering the same problem after my 4Runner sat for a couple months while I was doing some head work.
The thing that seems weird is that the code doesn't show up at start up. It only happens after I driven probably 100 ft. From what I've read the ingiter isn't a piece that is prone to intermittent failure. Once it's done it's done.
I messed around with mine a little today. I checked the distributor which was well within spec, I also checked for voltage at the ECM from the igniter. Now, I know to check the IGF signal a lab scope is needed but, it's not something I have readily available so I used my DVOM. I got a reading of approx .5V which I assume is a reference signal. And, I got .86V from the IGT wire. Seems to me the igniter is working.
Could it possibly be the distibutor?
I don't think it's the coil as it's only a couple years old, but I'm gonna test it in the morning and see what I find.
CC_yota is offline   Reply With Quote
Old 07-27-2009, 10:05 PM   #11
CC_yota's Avatar
Turns out is was the coil
Old 06-24-2011, 02:45 PM   #12
drkblu4runner's Avatar
im getting code 14 now. and one have any experience with the code? no misfire. maybe lack of power tho.... could it be the coil?
drkblu4runner is offline   Reply With Quote
Old 06-24-2011, 03:07 PM   #13
distributor and coil test correct from meter
Old 06-24-2011, 03:23 PM   #14
1styota4X4's Avatar
had a similar problem on my buddies runner and we are still trying to track the gremlin. Tested everything under the sun at the ECU and the part...took forever. My last guess is the little resistor in the silver box on the passenger fenderwell have not tested couldnt find a test for it. Gonna try replacing it once im out by his house and see if it makes any difference.
1styota4X4 is offline   Reply With Quote
Old 06-24-2011, 04:02 PM   #15
Lightbulb
think the box your talking about is the igniter and ther is a circut board in there.
i have replaced the igniter and coil b4 with one brom a junk yard... it fixed my last misfire, has been running good for a year now but still has this code that only comes up after a bit of driving
Old 07-24-2011, 04:00 PM   #16
1988 4Runner 127's Avatar
My 88 4runner will run for a few sec then die. it will idle fine for those few sec. The only code im getting is 14. I am lost.
1988 4Runner 127 is offline   Reply With Quote
Old 09-29-2011, 02:29 PM   #17
TRDevelopment's Avatar
Im bringing this back from the dead! Im having the same problem with my 88 4runner (3vze) that I just rebuilt the motor on. With an external source of fuel (brake cleaner to the throttle body) it will start. But it does not start by itself, the injectors are not triggering. I verified this using a niod light. Can anybody give me any pointers.
TRDevelopment is offline   Reply With Quote
Please help! smthwsn357 86-95 Trucks & 4Runners 7 04-11-2016 06:22 AM
ENGINE TROUBLE 3vze please help :( smiley52 86-95 Trucks & 4Runners 8 07-11-2015 06:16 AM
code 26 Roger Borba II 86-95 Trucks & 4Runners 2 07-09-2015 06:05 PM
1999 4runner HVAC Knob source cyclist231 95.5-2004 Tacomas & 96-2002 4Runners 2 07-07-2015 01:56 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
Tags
14, 1997, 22re, 25, 26, 4runner, breeze, check, code, d16z6, engine, igf, obd, toyota, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
