Engine Swap
Old 03-10-2008, 01:24 AM
bonesmcgraw's Avatar
Engine Swap
I have a 94 4runner with a v6 that I threw a rod in. I was wondering if anybody knows if the motor mounts on the frame are the same for the v6 as they are the 22re? I know the mounts that connect to the motor are different but I'm not sure about the ones attached to the frame.
Any help is appreciated.
Thanks in advance.
Old 03-10-2008, 02:35 AM
rdlsz24's Avatar
The frame mounts are more towards the front of the truck on the 22E:
https://www.yotatech.com/forums/f116...e-swap-132464/
Rob
Old 03-10-2008, 08:47 AM
thank you for the help
Old 03-10-2008, 08:49 AM
Victor's Avatar
The motor mounts, bell housing pattern are different. You could swap in a 3.4 from a newer 4Runner - there are hundreds of posts on that here if you search.
Old 03-10-2008, 10:56 AM
Elvota's Avatar
I think the 3.4 is going to be your best bet.
Good info threads here:
https://www.yotatech.com/forums/f160/
Old 03-17-2008, 09:04 PM
fuzzmaker's Avatar
Does anybody have any info or experience swapping a chevy v8 small block into a 2nd gen 4Runner. I would like to use my existing 5 speed manual trans and hopefully find a custom bell housing, motor mounts etc.
Thanks
Glenn
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
coryc85
09-09-2015 06:24 AM
Quick Reply: Engine Swap
