engine stumbles (22re)
The truck runs very well, but when i shift into 2nd and 3rd at a certain rpm range, i dont know exact because i dont have a tach. It feels like the engine stumbles and loses power but then goes right back to normal and speeds off.
The engine runs fine all the time other than at that certain rpm range. Anyone have an y advice
Im just throwing out ideas, when was the last time it had a complete tune up including the fuel filter ?, remove the throttle body and give it a good cleaning, and make sure the vacuum ports are not plugged, check all the vacuum lines for leaks.
ok i was thinking about the fuel filter and plugs. i havent checked them yet. i will start with that. i will check vaccum lines also.
Thanks for the responses
update on what i have done. I checked the throttle boby and it was a little dirty so i used amsoil power foam. it then started to run worse. so i pulled the spark plugs and the number 4 cyclinder was extremely dirty. So i changed the plugs and it runs like a champion. thanks for the responses
well i got ahold of a timing light today and it was a little retarted when you do the relays. it is supposed to be at 5 but it was at about 2 or 3. so i set it to 5 and now it runs even better. thanks for the help guys
steve miller
10-10-2015 01:40 AM
