Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Engine removal question
I'm pulling the engine and tranny on my '94 2WD pickup. The instructions I have talk about removing the #1 frame crossmember: is this really necessary and how do I know for sure which one it is?
Can someone tell me if there's a single place to disconnect the wiring harness that runs under the intake air manifold? I've pretty much disconnected all the sensors I can see but the harness continues onto the wheel well on the passenger side; there must be somewhere to disconnect it but I can't seem to find it. Would appreciate any help, advice, etc. TIA |
| Sponsored Links |
#2 (permalink) |
22re or 3.0?
On the 22RE, no reason to remove any cross member. I'd use a load leveler though, easier to manipulate the engine balance. There is no way to remove the harness from the 22RE, unless you remove it from the cab (at the ECU) and bring it back through the firewall. Disconnect all the wires, LABEL THEM, and take some photos of how it routes. That harness makes engine removal a bit of a pain.
__________________
http://www.22REturbo.net |
#3 (permalink) |
Staff
On a 2WD the #1 is under the oil pan. Easy to remove.
Unplug the wires from the computer and push them through the firewall into the engine comp. Lay them on top of engine and pull the engine out.
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
#5 (permalink) |
Excuse my ignorance, but I don't understand why you'd pull the wiring out of the cab. Remove the upper intake, label and unplug your connections on the block and tranny, pull it through the center of the lower intake, tie it up, and your ready to go.
Seems much easier and less time consuming than trying to pull everything through the firewall...
__________________
94' Pickup |
#6 (permalink) |
why would you want to pull the intake>> istead of just pulling the wires out of the cab.it takes 3 minutes..this way you can pull the harness with the motor
__________________
91 pickup 22RE, 5 speed swap, 35x12.5 TriXuS M/T-SOLD! 96 4Runner Limited-FOR SALE! 07 FJ |
#7 (permalink) |
You're not pulling the entire intake, only the upper plenum. Seems that harness has a good seal at the firewall while cutting and pulling will only risk shearing off connections.
Still not understanding why you want the harness out anyways ![]()
__________________
94' Pickup |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine Removal | Cid_4r | 86-95 Trucks & 4Runners | 13 | 12-06-2006 06:19 AM |
| Engine removal....who has done it?? | Cliff96SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 10-29-2006 05:34 PM |
| engine rebuild removal. | Sonofmayhem | 86-95 Trucks & 4Runners | 6 | 07-12-2006 09:08 PM |
| Engine removal tips | Dieselyota | 86-95 Trucks & 4Runners | 3 | 02-01-2006 03:05 PM |
| 3.4 Engine Removal Help | koyota93 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 03-04-2005 11:31 AM |
