Engine "rebuild" 22RE
Old 10-19-2015, 11:45 PM
-City Slicker's Avatar
my 1987 timing chain broke so I guess it's time to pull the engine and have it rebult..
I already had a broken exhaust stud that I need removed so I guess it must be meant to be..
I am currently looking for a place in so.cal to rebuild the engine.
I found two places for about 999-1050$, that will use my engine for the rebuild.
*any recommendations in SO.CAL?
My main question is, what should I be expecting for a "rebuild" ..?
I doubt the replacement parts are gunna be OEM; but
*are there certain parts that I should make sure ARE OEM; maybe the studs, tensioner etc?
I want to get it match ported, polished, and balanced.
*but what should I expect from this shop?
freeze plugs, rings, pistons, timing chain set, cover.. and what?
also what should I do while the block is pulled?
I'm definitely gunna do the clutch, probably gunna go OEM..?
& maybe upgraded injectors to match the supra AFM that I have in.
*so please let me know about any mods that might be convient at this time.
side note: My older friend that's helping me out is insisting on some ARP bolt set, I'm wondering if it's essential or not; seems pretty expensive?
--this post might or might not be in the right place so sorry in advance.
thank you!
LMk
Old 01-05-2016, 06:54 AM
KiloAlpha's Avatar
Hi city slicker, it looks like you didn't get an answer... I recently posted something similar in the newbie forum as my engine is currently being rebuilt. Hopefully your truck is back on the road by now and this is all moot.
JNapolitano
11-14-2019 07:46 PM
Littlerick
09-10-2015 08:57 PM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
jake_v
07-22-2015 03:17 PM
Quick Reply: Engine "rebuild" 22RE
