engine problems
Old 01-07-2010, 07:54 PM
94toyotapickup321123's Avatar
engine problems
i have a 94 toyota pickup 4x4 22re automatic and have had some problems i cant seem to figure out. When i am under the hood and press the throttle fast the engine wants to stall out. it will stall out if i keep pressing the throttle quick. i donk know whats going on. tps is adjusted to specs. please help
Old 01-08-2010, 06:48 PM
TORTIS's Avatar
fuel filter. unplug tps and see how it does.
Old 01-09-2010, 10:00 AM
i have replaced the fuel filter and when i unplug the tps the idle goes up and the truck runs fine. jus not good acceleratiaon. its an automatic so i need the tps plugged in for it to shift smoothly.
Old 01-09-2010, 10:16 AM
dark_fairytales's Avatar
check all the simple stuff first.
Grounds
plugs/ wires
air filter
clean throttle body
make sure the tps is adjusted correctly
only after all that is checked, you may have a bad tps or fuel pump
Old 01-09-2010, 03:39 PM
TORTIS's Avatar
you say the TPS is adjusted, but is the voltage reading right?
Old 01-09-2010, 08:38 PM
i have it adjusted correctly and it is a new tps. lets see how do you check the voltage with a digital meter. will it work the same as the analog meter? also i did say i washed my engine bay down and i believe it started right after that. the engine overheated once but it ran fine before i washed the bay down. and the tps was replaced after the engine bay was washed. One more problem the engine misses quite a bit when you keep it at a steady 2000 rpm... i dont kno?
Old 01-09-2010, 09:07 PM
bipolarandproud's Avatar
Spay the electrical connections with wd40 because it may have gotten water in them .
Old 01-09-2010, 10:12 PM
there is no water in the plug. i sprayed some compressed air and blew out the conector. i still dont get the whole missing problem
Old 01-10-2010, 04:55 AM
tim a.'s Avatar
take off distributor cap and look for moisture.sure sounds like your problem,
Old 01-10-2010, 01:57 PM
i have replaced the cap with a new one and i am sure there is no moisture in the cap.
Old 03-03-2010, 06:49 PM
just call me smithy's Avatar
what ever hapened to this thread? my 3.o has a low idel wh the TPS plug in and when its un pluged it idles just fine 800 I would realy like to know how this ended
Old 03-03-2010, 06:54 PM
Tracey98277's Avatar
what i find really frustrating about this thread is that everyone has a common problem, engine runs better without TPS. and in this whole thread no one actually went and double checked the TPS with a multimeter. i'm not saying the TPS is the problem but it sure sounds like it is worth checking if the motor runs better with it unplugged.
Old 03-03-2010, 06:56 PM
i know this is a dead thread but...
here is a lesson for everyone, don't assume, go check, it is easy to do, and its better to be sure.
steve miller
10-10-2015 01:40 AM
Yota.Jay
07-23-2015 08:08 PM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: engine problems
