Engine Oil Leak: Anyone Know How To Stop It?
Old 08-21-2011, 08:51 AM
andlours's Avatar
It appears to me that I've got some oil leaking from my engine block on the top. It's not a ton, but it's just a hassle. Is there any simple way that I could fix this? I'm new to all this, so pardon me if I'm completely wrong/asking a stupid question. Thanks.
Attached Thumbnails Engine Oil Leak: Anyone Know How To Stop It?-imag0080.jpg   Engine Oil Leak: Anyone Know How To Stop It?-imag0081.jpg
Old 08-21-2011, 09:05 AM
mightymouse's Avatar
It seems as though there are a couple potential spots that are leaking on your valve cover. One is the line that is a thicker line to the throttle body. To fix this replace the line, add small clamps to said line. The other spot could be your pvc valve. If it's leaking there ( the other similar sized line towards the rear of the valve cover) Check and replace the line along with the pvc valve with the grommet as well. Basically "see where there's oil coming out? replace the faulty part"
Old 08-21-2011, 09:07 AM
92 TOY's Avatar
looks like you are leaking from the PCV valve grommet. costs a few pennies at the store....get a new PCV valve while you are at it....about $6. those grommets get brittle and hard.....PCV gets clogged. good cheap insurance.....good easy job to do too
Charecter1
11-06-2023 10:08 AM
bigjstang
08-25-2021 12:41 AM
icentropy
07-11-2015 07:21 AM
God's Bounty Hunter
07-08-2015 12:54 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Engine Oil Leak: Anyone Know How To Stop It?
