Engine Light, What does it mean?
Old 06-11-2008, 07:43 AM
dwiegand's Avatar
The engine light on my 93 3.0L P/U recently turned on and I can't figure out why it would be on. I replaced the radiator, the hoses, and the thermostat about a month ago after the stock radiator blew the top seam out. I was wondering if anyone knew what could be causing the check engine light to come on.
Old 06-11-2008, 07:44 AM
76ANTHONY's Avatar
do a search on how to find out what code it is.
Old 06-11-2008, 09:05 AM
dwiegand's Avatar
I purchased the diagnosis tool and should be receiving it by the end of the week. Are some codes more common than others on the 3 liter?
Old 06-11-2008, 09:09 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
You don't need the tool, but it's nice to have one.
In the grey diagnostic box....next to the fuse box under the hood.....jump/short the TE1 and E1 terminals. Turn the key on and count how many times the CEL flashes.
As far as the search feature, it's always encouraged to use it because often you can get more answers than you would in one single thread......and much more quickly. In which case, you will see that there are a lot of reasons the CEL can come on.
Old 06-11-2008, 03:51 PM
just a 22re's Avatar
the check engine light is on because you need to change your oil
when was the last time you changed your oil????
lol no just do what my friend just posted its easy and you dont need a tool for it
Old 06-11-2008, 04:42 PM
Squeebs's Avatar
Check engine light is always emissions.
Start easy.
get a new gas cap.
Old 06-11-2008, 04:51 PM
My99's Avatar
NO. Don't buy a new gas cap, and no, it's not always emissions. As Matthew stated, pull the codes by counting the flashes of the CE light. (Run a search on check engine light codes or "diagnostic codes" and you'll see how this is done). Or wait until you get your diagnostic tool. Either way, post back up what you find here, and we'll try to help you trouble shoot.
Old 06-11-2008, 05:04 PM
Marc's Avatar
Start easy.
get a new gas cap.
Don't just throw parts at it.
Besides, a bad gas cap won't throw a code on a 2cnd gen.
Old 06-12-2008, 08:36 AM
AusTex's Avatar
Or take it to the VatoZone and they can code check it. Then you are already at the parts store to get what you need.
smthwsn357
12-04-2023 02:08 AM
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: Engine Light, What does it mean?
