emergency brake light stays on
Old 03-11-2010, 03:10 PM
rustyboltz's Avatar
On my 88 base model pickup, my emergency brake handle will not stay down to turn off the emergency brake light on the dash. It will stay one click up. Any ideas what I need to do to get it to stay all the way down?
Old 03-11-2010, 03:19 PM
mightymouse's Avatar
If it's disengaged and not hung up just unplug it or at least that's what i did 6 years ago. Just don't drive off with the parking brake on.
Old 03-11-2010, 03:35 PM
94svt50's Avatar
take a look at the back drum brakes to make sure its not sticking there. Mine does this from time to time and I have to wack it with a stick.
Old 03-11-2010, 03:38 PM
rusche's Avatar
Could also be your brake master cylinder is low. Check your fluid.
Old 03-11-2010, 03:44 PM
annoyingrob's Avatar
^^ Word. That light serves more than one purpose.
Old 03-11-2010, 03:47 PM
Junkers88's Avatar
Indeed! The MC has a sensor in it that will light up the E-brake light to let you know if it's low on fluid.
Check that first and get back to us.
Old 03-12-2010, 12:19 AM
rustyboltz's Avatar
ihave checked the master cylinder and it is full of fluid. I can twist and push the e brake handle down the one notch and the light will go off and stay off until the e brake handle moves up one notch. I will have to take the drums off and look at the rear brakes. I was wondering if there is a return spring that may be getting weak or is there a place that is a little dirty or gummy that maybe i should put some spray lube on.
Old 03-12-2010, 03:17 AM
WatsonToyota's Avatar
try working the e brake handle real good pullin it out with a lil more force than usual then releasing it a few times....
mabye that will generate a tiny bit more of play in the cable
ashersullivan88yota
01-18-2022 05:37 PM
fountain
12-31-2015 06:08 AM
Odin
07-15-2015 09:28 PM
Sandman
07-14-2015 12:36 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: emergency brake light stays on
