electronic supercharger
Old 01-22-2008, 08:11 PM
toyotarunner92's Avatar
anyone know about the Thrton electronic supercharger?
http://www.electricsupercharger.net/index.php
it come swith a manual boost control switch. i would only run it at about 2 -3 PSI. i know people sya that they dont work, but these come with EPROM chips and s/c that was built for your vehicle.
tell me what you think.
-andy
Old 01-22-2008, 08:16 PM
Anubiscougar's Avatar
eh..... W.O.M.
W.O.M. = Waste Of Money.
The pic that they have up there on the press section is of a turbo anyhow... turbo = not electric... lol.
There's only one electric "supercharger" that i've seen that i would ever believe to do anything... it was a twin or... tri screw(i think twin.. tri doesn't sound like it would work...) unit, with two HUGE motors on it. Pretty big sized piece... Duno where i found it at.. i lost the link now. It was crazy expensive though, and the company said you couldn't run it more than x seconds, cuz it would drain your battery so bad or something, or hurt the motors.. something dumb.
You want boost, buy real boost... or go home.. You want cheap, EFFECTIVE speed, buy nitrous.. just do yourself a favor and set it up correctly.. either way, you're spending over a grand.. near 2 even for the RIGHT setup.
Old 01-22-2008, 08:23 PM
Red3.slow's Avatar
no not again!
Old 01-22-2008, 08:25 PM
ozziesironmanoffroad's Avatar
stay away from any kind of electric 'turbo' or 'supercharger'. period. dont care what anyone says, they are a waste of money. only kind of performance you can gain is from mechanical. well, in terms of superchargers and turbo anyway.
Old 01-22-2008, 08:28 PM
Staff
DeathCougar's Avatar
bahahaha
Scam scam scam
Old 01-23-2008, 03:04 AM
Ganoid's Avatar
here ya go .
http://www.turbomagazine.com/tech/04...ger/index.html
I have seen a few others as well.
Old 01-23-2008, 03:21 AM
ovrrdrive's Avatar
Leafblower...
Old 01-23-2008, 04:41 AM
fastkevman's Avatar
If you go to the Forum section of that website and look at the "Installed" threads.....the pictures are of Vortech superchargers.....blow them up, you can read "Vortech" on the castings.
I wonder if they would like to know of this "scam" site and try to sue the owner!
Old 01-23-2008, 05:10 AM
idanity's Avatar
you would do better if you just dropped some weight.
cut out all carpeting, extra seats, spare tire, and just strip it down to its bare essentials.
run on 1/3 tank at most.
over-inflate your tires
then,
port/polish your head/exhaust side.
install higher grind cams
drop a few ratios on your driveline gearing
or, like above post, if you want fast, boost. (i'm talkin 12psi or more).
but, if you really need speed, may i suggest a trailer and a track bike.
Old 01-23-2008, 05:52 AM
fastkevman's Avatar
I reported this site to Vortech and gave them my email address, I'll post if I get a response.
Old 01-23-2008, 08:23 AM
notanymore's Avatar
just say no.
Old 01-23-2008, 10:53 AM
just a 22re's Avatar
this is what i would do sounds really dumb but it might just work here...... buy it!!!!!!!!!! take it all apart dump the ele motor and install a pully ok now mount it just like a real sc!!!!! and that should just to the trick for about 200 bucks or so cause all you really need as the case and then just boost like all he!!
Old 01-23-2008, 10:56 AM
MMA_Alex's Avatar
Its gotta be real! they want a whole whopping $99.99 for it!
Old 01-23-2008, 11:00 AM
TFJ-4runner's Avatar
Just stick a blower in your intake!
Old 01-23-2008, 11:59 AM
lol thanks guys. i never ended up ordering it. i dont really want to go fast. some friends of mine just put the idea into my head, but then again it isnt their engine.
Old 01-23-2008, 12:35 PM
dcg9381's Avatar
I've seen leaf blower dyno runs that indicate gains.
However, this thing looks shady as heck.
First, they indicate that they'll chip your vehicle:
We provide a custom EPROM performance chip with your order to optimize your vehicles ECU. It is very easy to install, instructions to do so are provided with your order.
That'd be a new product for the 22re or 3.0L.
No dynos, no real photos.
The domain registration is hidden - it's protected by a company that shields actual registration. Who knows who owns the company.
Their diagram shows a switch to the "turbo" - most mechanical switches are limited to about 20amps @ 12V DC.
Your average leaf blower pulls 12amps at 120V AC. That means 1440 watts.
To get that out of your battery, 1440 watts / 12v = 120 amps... That's way too big for anything short of a battery terminal switch.
Old 01-24-2008, 11:14 AM
needsomecam's Avatar
that looks like it belongs in a jet ski!
sorry but:
real blowers have belts not 2 starter motors^^^
Old 01-24-2008, 12:14 PM
elripster's Avatar
That sad thing is electric supercharging has huge potential in higher voltage systems like this in hybrids. With low voltage systems the resistive losses are larger due to the high current requirements. (power = voltage X current)
A good friend of mine did his mater's thesis on this and it turns out an electric super charger can be more efficient than a belt driven one. However, not on our 12V electrical systems.
Frank
Old 01-24-2008, 12:36 PM
ewong's Avatar
at lest the starter motors appear to have enough "oomph" to actually do something (versus a leaf blower)
Basic physics sez its a loser.
Old 01-24-2008, 12:54 PM
saitotiktmdog's Avatar
I remember seeing a video of a civid with a leaf blower hooked up to it. Gained power. Then they sprayed notrous into the leaf blower. More power. But you cant really install a leaf blower on your car. Just use the nitrous on your car and screw the leaf blower. Iteresting none the less.
Quick Reply: electronic supercharger
