EGR temp sensor resisitor 10K
Old 03-03-2010, 11:29 AM
diablo's Avatar
Anyone have info on putting a resisitor on the wires going to the egr temp sensor so that light shuts off????
Old 03-03-2010, 12:32 PM
Junkers88's Avatar
Yup. If you put a 10k resistor in there and then pull the ECU fuse for a few seconds so the codes clear then the light won't come back on.
Did it to mine and the codes have been gone for a while now. Got the resistors at Radio Shack, .99$ for 10 of them although I only needed 1.
Old 03-03-2010, 12:35 PM
diablo's Avatar
thanks , I will try it .
Old 03-03-2010, 02:28 PM
DupermanDave's Avatar
Was it a 10k resistor or a 1k? I thought I read it was supposed to be a 1k.
Old 03-03-2010, 02:59 PM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
It sounds like they're using a resistor to bridge the two wires going to the sensor, which likely measures temperature as a result of a resistance change. If it's made out of a conductive material then an increase in temp causes an increase in resistance, but if it's made out of semi-conductive material, the reverse is true. It seems like putting a resistor on simulates a given temperature in the EGR (assuming the EGR is blocked off) to trick the ECU, but to know what the best number of ohms would require you to measure the resistance of the sensor with an ohm metre while it's subjected to changing temperatures, and to select one that simulates a temp that the ECU won't be mad about.
Old 03-03-2010, 04:34 PM
Junkers88's Avatar
10K. I did this right before my emissions test (which produced results so good that I qualified for a two year sticker) so that the CEL wouldn't be on which is an automatic failure.
Old 03-03-2010, 06:15 PM
diablo's Avatar
thanks to everyone who helped on the resistor thing I will post in 3 days and tell if the lights back on or not
Old 03-04-2010, 06:52 PM
O Holy P's Avatar
When I removed my EGR, I never found any temp sensor plugged in to anything. :confused:
Old 03-04-2010, 07:09 PM
Teuf's Avatar
Pic would be nice, for those of us that go mmmmmm when looking at the EGR, including me.
Old 03-05-2010, 04:23 AM
diablo's Avatar
the egr temp sensor is on 22re c, C being california models and is located on the firewall side of the intake on top its threaded into the intake and has 2 wires going to the wiring hatness. hope that helps. diablo
AudiKev
09-03-2019 02:55 PM
rjtrials
08-06-2015 07:25 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: EGR temp sensor resisitor 10K
