egr removal
Old 01-16-2008, 08:40 PM
cweich's Avatar
egr removal
If I remove my EGR valve, is there anything I need to do to the the computer it is still working?? 1988 22RE with a manual. The only reason I am removing it is in the way, not the valve its self, but the plate on the back of the head, I need that other half in for a project I am trying.
Old 01-16-2008, 08:50 PM
Elvota's Avatar
I don't believe the computer will care... but it might effect your emissions if you need to pass that for licensing in your area.
Old 01-16-2008, 09:04 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Watch the O2 sensor, also. It's going to throw the exhaust mix off a bit.....in relation to what the ECM is programmed for, anyway.
If yours doesn't have an EGR temp sensor, there's nothing there to "trick" in the way of the electrics. On the 3vze, with the temp sensor, one uses a little resistor. I'm sure the same for the 22re. I forget the specs on that in this moment. It's in numerous other threads, though.
Old 01-17-2008, 05:18 AM
cweich's Avatar
No emissions to to worry about. Sounds good, Thanks
Old 01-17-2008, 08:20 AM
LS1Steve's Avatar
it will run fine but you will have a check engine light. throw a 10k resistor across the egr connector on the end that goes to the computer and that will simulate a working egr and take care of the light
Old 01-17-2008, 10:35 AM
TNRabbit's Avatar
You can pick up a pack of 4 of these resistors @ Rat Shack for next to nothing.
Old 01-17-2008, 12:40 PM
nate V's Avatar
What kind of project are you trying to do???
Blamalam
03-12-2022 07:34 AM
Colington
08-13-2015 02:21 PM
e_richard
07-30-2015 06:50 PM
montanatruck
07-25-2015 03:45 AM
Snort
07-09-2015 03:58 PM
Quick Reply: egr removal
