YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-05-2008, 09:20 PM   #26 (permalink)
js9924's Avatar
Heres what you do. Take a 10k ohm resistor and push it into the connector that goes to the temp sensor. Cover it with some electrical tape or heat shrink or something and your code should go away. This will trick the ECU into getting a "good" reading form the sensor.
__________________
'94 T100 3.0
My mods page: http://www.angelfire.com/fl4/dmb
js9924 is offline
Sponsored Links
To remove this ad, register today!
Old 05-05-2008, 10:13 PM   #27 (permalink)
Quote:
Originally Posted by Alex 400 View Post
so did most of the non-california trucks come with the plug that shorts out the wire? Also, does shorting the wire make the computer think it's at the right temp? How does this sound for a plan? Cut the wires. strip it back a little, twist together and then put a small bit of heat shrink on it and then cover it up with the stock heat shield. how 'bout it?
Yes, i think most if not all non-california trucks came with that plug. Shorting the wire makes the computer think its at the right temp, so there should be no more CEL after that. That is if it is your sensor that is bad. If the sensor is currently fine, then it will not change anything.
Yes i was told if you twist the wires together it will provide the same effect as having the cap. Shoot, next time you at a pick n' pull just grab the cap and then you can remove the sensor! One less thing in the engine bay !
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear
Quote:
Originally Posted by 4rnr View Post
I have NOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
904_runner is offline
Old 05-05-2008, 10:18 PM   #28 (permalink)
Alex 400's Avatar
ok makes sense. Yeah if i get the plug i could just have my dad (hydraulic boat steering salesman, etc.) bring me a plug to plug the hole where the sensor was before. hmmm i like where this is going.
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6 3vze, 5-speed, 31/10.50-15 toyo A/T, All Pro 1.5" coil springs, bilstein front shocks, doetsch tech mv12's rears, , MC heavy duty clutch
feasable wish list:
33x10.50 BFG KM2
4.88's
ARB air locker
other ride:2001 Honda XR400R
Quote:
Originally Posted by slisdexia View Post
I blame the automatic transmission for the wussification of America
Alex 400 is offline
Old 05-05-2008, 10:36 PM   #29 (permalink)
If you take the sensor out, there is no need to plug the hole.
__________________
My build thread
Old 05-05-2008, 10:45 PM   #30 (permalink)
Alex 400's Avatar
isn't the sensor screwed into the area where there is exhaust so that it can get a temp reading? if i take it out it would leak exhaust, wouldn't it?
__________________
feasable wish list:
33x10.50 BFG KM2
4.88's
ARB air locker
Alex 400 is offline
Old 05-05-2008, 10:51 PM   #31 (permalink)
No, it just screws into the metal, it doesn't actually go through. I think it just detects the temperature of the metal, not the actual gases!
__________________
My build thread
Old 05-06-2008, 06:18 AM   #32 (permalink)
Alex 400's Avatar
well thats handy! Thanks!
__________________
feasable wish list:
33x10.50 BFG KM2
4.88's
ARB air locker
Alex 400 is offline
Old 05-09-2008, 07:38 PM   #33 (permalink)
Seems I spoke to soon. My CEL came back on. So I've got a question on this whole thing. In the FSM when it talks about testing the EGR system. Page EG2-149 section 5. If I'm not getting any vacuum with the engine warm and rpm's at 3,500. What part does that indicate is bad? The VSV or Vacuum modulator?
Oh and wouldn't tricking the ecu into thinking that it's getting enough recycled gas harm performance and possibly reduce gas mileage? As opposed to fixing it?
__________________
'93 4Runner 3vze A/T 2wd 175k
Yeah it's 2wd but it's good for hauling my tools around.
l3fty is offline
Old 05-09-2008, 08:14 PM   #34 (permalink)
4Crawler's Avatar
The VSV sends vacuum to the modulator, the modulator passes it to the EGR. Might be as simple as a clogged vacuum line.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
EGR code 71 Alex 400 86-95 Trucks & 4Runners 28 02-18-2008 09:59 AM
New EGR valve + code 71. what gives? 95RunnerSR5 86-95 Trucks & 4Runners 22 07-18-2007 06:55 PM
EGR malfunction code 71? Silverunner 86-95 Trucks & 4Runners 10 01-19-2007 02:49 PM
EGR Code 71 xentrino 86-95 Trucks & 4Runners 3 11-13-2006 07:26 PM
EGR error code 71 okidoc 95.5-2004 Tacomas & 96-2002 4Runners 6 08-22-2003 09:03 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
