Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
EGR code 71
My EGR is throwing a code 71 and it doesn't really effect performance as much as it does the gas milage. My milage went from 18 or 19 to 13 or 14 and it has been getting worse. the code comes on about every month and half or so, then i reset it and it goes away for a while then it comes back on. I have noticed it coming on when it probably gets the hottest, like after going up a long hill, heavy traffic, or pulling a trailer. Is this the pyrometer in the egr or the EGR valve sticking?
Thanks
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6 3vze, 5-speed, 31/10.50-15 toyo A/T, All Pro 1.5" coil springs, bilstein front shocks, doetsch tech mv12's rears, , MC heavy duty clutch feasable wish list: 33x10.50 BFG KM2 4.88's ARB air locker other ride:2001 Honda XR400R |
| Sponsored Links |
#2 (permalink) |
Code 71 can be a vaccum leak. Try replacing the vaccum hoses to the EGR valve. If that does not work, I think you test the EGR by putting a vaccum pump on the EGR. If the engine does not immediately runs rough, you have a bad EGR valve.
#3 (permalink) |
Did you ever find the problem? I am having the same problem with some rough idiling..
Thanks Shannon
__________________
95 4-Runner 4X4, auto, SR5, 3.0 V6 |
#4 (permalink) |
so code 71 is a vacuum leak? mine is throwing that code too
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22RE 258,000 miles on original motor pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#5 (permalink) |
No its egr. I have noticed that it only turns on when the engine is really working hard or when i am off road. From what i learned from the service manual is that it opens when it gets to a certain temperature. mine does fine until i get on the freeway for more that 10 miles or when i am off road and not much air is flowing past it. This leads me to believe that it is stuck shut and i need a new EGR valve, i just haven't done anything about it yet.
__________________
#6 (permalink) |
Mine displays the same exact symptoms, however I took the valve off, cleaned it, and hooked it up to a vacuum pump. It actuated fine, and even let the carb cleaner through. (took a lot of black junk with it). So I don't think that is your problem. I have decided to ignore it.
__________________
'95 4Runner SR5 running 31x10.5's. Installed the "YELLOW HOSE OF TEXAS MOD" Stripped the running boards and evened out the rear with spring spacers |
#7 (permalink) |
Egr
Here is a link with the codes:
http://www.off-road.com/toyota/tech/codes/ Code 71 for the EGR could be a vacumn leak which is preventing the valve from opening or the switch from working due to a vacumn leak , the switch whether the Temp controlled vacumn switch or the temp controlled electrical switch could be causing the problem as well. Also if you have the EGR with the Temp Sensor ....that could be bad and not telling the ECM the valve is open . Could be alot of things depending on the layout which is why you need to use the Service Manual to check operation of these different controls and understand your model year layout and function so you know where to look .Here is a 93 FSM online version : http://personal.utulsa.edu/~nathan-buchanan/93fsm/ scroll down to get to the 3VZE if that is what you have , the 4 banger is first , and then under "engine" and then "emission control" , you will see that over the years several diff. types of control systems have been produced so you have to go through them and find yours and then you can see what controls and or switches what for the system you have , once you do that you can use the FSM to troubleshoot any of the controls whether temp/electrical , temp/vacumn or exhaust temp switched . The other angle is to remove the EGR altogether which I am going to do on mine soon , then I do not have to worry about the booger anymore .
__________________
Guy '91 ExCab Dlx Longbed/3VZE-Fast/Stock 2WD/5spd Manual '95 GMC Jimmy SLS 4WD/4.3L Vortech/Euro Susp and Motor Package/Tow Package F.A.I.T.H. Forsaking All I Trust HIM Matthew 19,20 : 19 I say again unto you,that if two of you shall agree on earth as touching anything they shall ask,it shall be done for them of my Father which is in Heaven 20 For where two or three are gathered in my Name,there Am I in the Midst of them Last edited by n4ynu1010 : 10-09-2007 at 07:29 PM. |
#8 (permalink) |
Egr
I failed to notice that you have a '94 , the 93 FSM I linked previously I believe would cover your motor but if not here is the link where you can go online and either download or use online the manual for your model and year :
http://www.ncttora.com/fsm/index.html Sorry about that , I need to pay more attention.......
__________________
Guy '91 ExCab Dlx Longbed/3VZE-Fast/Stock 2WD/5spd Manual '95 GMC Jimmy SLS 4WD/4.3L Vortech/Euro Susp and Motor Package/Tow Package F.A.I.T.H. Forsaking All I Trust HIM Matthew 19,20 : 19 I say again unto you,that if two of you shall agree on earth as touching anything they shall ask,it shall be done for them of my Father which is in Heaven 20 For where two or three are gathered in my Name,there Am I in the Midst of them Last edited by n4ynu1010 : 10-09-2007 at 07:32 PM. |
#9 (permalink) |
hey,
not to hijack the thread or anything...but thanks for that link..ive been looking forever for a link like that... does anyone know if theres much difference btween a 91 truck and a 93.... |
#10 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Nothing too signicant to prevent you from using the '93 manual information, if that answers your question.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#11 (permalink) |
so it might not be the egr at all, but the vacuum switch that operates it?
__________________
#12 (permalink) |
Egr
Yes , it may be a vacumn issue , it could be a dirty throttle body which could result in a stopped up vacumn port , could be vacumn line has trash in it (blow them out with rubber safe cleaner or air) or could be one of many vacumn switches , temp controlled electrical switch or if you have the Temp Sensor (kinda like an O2 sensor) then that could be bad and not telling ECM that EGR is open , use the manual and find the system you have and then you can troubleshoot controls
__________________
Guy '91 ExCab Dlx Longbed/3VZE-Fast/Stock 2WD/5spd Manual '95 GMC Jimmy SLS 4WD/4.3L Vortech/Euro Susp and Motor Package/Tow Package F.A.I.T.H. Forsaking All I Trust HIM Matthew 19,20 : 19 I say again unto you,that if two of you shall agree on earth as touching anything they shall ask,it shall be done for them of my Father which is in Heaven 20 For where two or three are gathered in my Name,there Am I in the Midst of them |
#13 (permalink) |
I saw in another thread that said that if you hook a vacuum pump to the egr valve and pump it and it runs rough then its is a vacuum issue not the egr valve. I did this today and pumped it once and the engine stumbled down a few hundred rpm and pumped it again and it almost died. So i think the egr is fine, but maybe it is a switch. I am not overly worried about it though.
__________________
#14 (permalink) |
I mean really, besides the annoying light, what is it hurting? I priced a new temp sensor (O2 thing) last night $145.00!!!!!!!!!!!!!!
I'll live with the light.
__________________
#15 (permalink) | |
Quote:
Yeah if the light comes on i always check to make sure its just the egr valve, just in case. but yeah it has been on and off for a bout 6 months now.
__________________
#16 (permalink) |
By pass it, its a useless piece...
__________________
My Rig - 1992 TOYOTA 4RUNNER, 3VZE V6, R150 5 Speed Transmission (5 Speed Swap, running on AUTO ECU & Wire Harness) 4x4, ( 219,000 miles ) all bonestock. Replace HG at 215,000 miles ( MLS HG). 1992 Toyota 4runner V6 A/T ECU/ECM for sale, part # 89661-35770, asking price at $150.00 USD. Free Shipping in the US. |
#17 (permalink) |
I'd like to, but can't find a good how-to. Know where one is? preferably with pics??
__________________
#18 (permalink) |
Egr
Well the downside to ignoring the O2 sensor is that is how your ECM controls the mixture under many different conditions , if the O2 is bad that needs to be replaced ...............EGR on the other hand if its not working and not stuck open then no problem really .
__________________
#19 (permalink) |
No, my O2 sensor is not out. The temperature sensor is basically a little O2 sensor. It does nothing more than open/close the egr valve to my knowledge. Correct me if I'm wrong anyone.
__________________
