EFI Throttle body
Old 12-19-2008, 05:29 AM
muddpigg's Avatar
EFI Throttle body
Has anyone taken one down to clean/rebuild? My FSM doesn't seem to have a drawing of it. Is there any trickey parts or is it pretty straight forward? Thanks.
Old 12-19-2008, 06:29 AM
just a 22re's Avatar
its easy theres 4 bolts on them and if its the 22re the bottom right is goin gto be the hardest to get to other then that there the same as any other TB out there just smaller lol
Old 12-19-2008, 03:17 PM
muddpigg's Avatar
Got it 4 bolts, unhook some coolant hoses, vacuum lines, and TPS wires throttle body is off. Now does anybody have experience rebuilding the Thottle body?
'86 22RE if it matters.
Old 12-19-2008, 03:57 PM
space-junk's Avatar
is there a way that you can bore it while its out...
i mean, you prolly could, but where could you get a new throttle plate/butterfly valve for it?
Old 12-19-2008, 04:40 PM
muddpigg's Avatar
LCE sales one as a bored out rebuilt unit for a little less than a OEM unit.
http://www.toyotacatalog.net/M1WebGe...5-95351B936E0D
Throttle body, van, manual trans 86-89 list $531.01 you pay $373.51 http://www.toyota-parts-dealer.com/parts.htm
Old 12-19-2008, 05:02 PM
Bako88's Avatar
Space-Junk - I think bored out T.B.'s may fail CA smog check. Downey Off-Road sells them and small print says not legal for use in CA. I was thinking of getting one in the future, but I'm not sure it's worth the hassle. You have to adjust the Air Flow Meter when you run a larger T.B. also
Old 12-19-2008, 05:16 PM
space-junk's Avatar
now, what about the 3vz?
Blamalam
03-12-2022 07:34 AM
jetpilot
08-15-2015 06:48 AM
mtc1105
08-04-2015 08:06 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: EFI Throttle body
