efi help
Old 03-05-2008, 03:22 PM
mudtoy1986's Avatar
efi help
i own an 86 toy pu carbed im swaping to efi will the carbed fuel lines work or do i need efi fuel lines
Old 03-05-2008, 04:05 PM
cutboggers's Avatar
You'll need the efi line so that it can screw into a fuelfilter right there on your block. + u need the EFI tank for the high pressure pump
Old 03-05-2008, 04:37 PM
mudtoy1986's Avatar
thanks for the info but will i need to change my head as well or can i use the carbed head maybe a cam swap or can i use the old one
Old 03-05-2008, 04:39 PM
rowdy235's Avatar
head should work
Old 03-05-2008, 04:44 PM
myyota's Avatar
The head and cam will work, you just need everything else to make it all work.
Old 03-05-2008, 05:10 PM
mudtoy1986's Avatar
sweet well i think i have all i need
intake exaust entire harness tank and pump
all that is left i guess is the acelorator cable and fuel line wich ill get from toyota the fuel line that is if they cost the same as the one for my 90 its about 60 bucks i work in a salvage yard so parts are pretty easy for me to get i scored all the efi stuff for free
Old 03-05-2008, 08:53 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Really? So, there's provision for the intake manifold and the EGR?
Old 03-06-2008, 02:18 PM
mudtoy1986's Avatar
provision? whats that mean ? well the egr was seperate from the intake
Old 03-06-2008, 05:32 PM
thook's Avatar
Means something provided....as in, the design of the head provides for EFI lower intake and EGR components to be attached to the head....like openings/ports and studs or bolts, etc. So, there is provision or provisions for them.
Old 03-06-2008, 05:59 PM
cutboggers's Avatar
Well actually the carb and efi cam specs are different however
I would not think that you nor me could tell the difference between
them.
Old 03-09-2008, 08:30 PM
84sr5yoty's Avatar
them.
No they aren't, they're the same exact part#. I have the original toyota micro-fiche slides.
Old 03-23-2008, 02:30 PM
cutboggers's Avatar
hmmm maybe just good aftermarket ones are different.
Old 03-23-2008, 02:50 PM
jsn_stockard's Avatar
Knock Sensor!!!!!! 22r does not have a place for a knock sensor and you need it
Old 03-23-2008, 02:53 PM
cutboggers's Avatar
not to get too off topic but what exactly does the knock sensor do?
Old 03-23-2008, 02:59 PM
In a nutshell, it kinda works like a vac advance. It adjust the timing to keep you from trashing the engine. My friend bought a 93 4x4 that had a 22r in it that they put efi on. When he would hit 2grand the check engine light would come on and it would loose power. It threw knock sensor code and engine was dead in two months. I wouldnt do it.
Old 03-23-2008, 03:19 PM
cutboggers's Avatar
lol yeah not good. So could the knock sensor be the prob with some of these efi 4 bangers running kinda doggish on the bottom end? like below 3k rpm
Old 03-23-2008, 06:18 PM
Usually not. Usually you start off fine then get a sudden power drop anywhere from 1500 to 2000 rpm and a check engine light. It usually does it every time you dirve it. The power drop in my friends truck was very noticable, like he lost 5o horses.
Old 03-24-2008, 02:42 PM
cutboggers's Avatar
lost 50 horses? damn. musta been down to nothin
Old 03-24-2008, 03:15 PM
TOYOTA 1's Avatar
haha, ya that would put me at negative 25hp
Gutted91
01-03-2020 09:48 AM
mreagen
10-05-2015 04:27 PM
rmill05
09-27-2015 01:43 PM
Boomer8404
09-20-2015 06:15 PM
themightykhoner
09-18-2015 02:28 AM
Quick Reply: efi help
