EFI fuse - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-03-2007, 09:22 PM   #1 (permalink)
EFI fuse
I was wondering what the EFI fuse in my fuse box under the hood actually is for. One of my friends told me it was for my fuel pump but im not sure. If I wiggle it back and forth and up and down i can get a solenoid or something to click every once in awhile. What is doing this clicking?? When i go to my friends truck and turn on his key all i have to do is pull out the fuse and put it back in and it clicks. I tried cleaning my fuse connections with an emory board and I pushed the contacts for the fuse towards each other to make sure I was getting a good connection, but still I have no luck. do i need to replace my whole fuse box? thanks in advance.....
David
david28 is offline
Old 04-03-2007, 10:53 PM   #2 (permalink)
bumps
david28 is offline
Old 04-03-2007, 11:27 PM   #3 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
its for your EFI...hence the EFI fuse. It supplies power to the EFI system from the battery.
Try cleaning the fuse, and the contacts again, and really well. Chances are its all corroded. btw the clicking you are hearing is the EFI Relay in the fuse block.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by AustinTaco View Post
the last person to work on the front used the "chizzel my dizzel" method
DeathCougar is offline
Old 04-04-2007, 09:10 AM   #4 (permalink)
would this fuse being messed up give me problems with my fuel pump?
david28 is offline
Old 04-05-2007, 12:52 PM   #5 (permalink)
figured it out today...turns out the efi fuse was running my fuel pump. i was able to get a good connection by wrapping one blade of the fuse with a thin piece of metal. now my truck runs great.
david28 is offline
Old 04-05-2007, 01:11 PM   #6 (permalink)
TNRabbit's Avatar
You need to go to the dealer & get a replacement ASAP. This is a good way to fry your entire ECU, which will cost a helluva lot more than an EFI fuse.
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap
3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/
Quote:
Originally Posted by Junkers88 View Post
Like the good book says "you can give a man a Toyota and he will wheel for a year, you can teach a man Toyota and he will wheel for a lifetime."
yotatech 3:16
TNRabbit is online now
Old 04-05-2007, 01:52 PM   #7 (permalink)
cweich's Avatar
Is the fuse you are talking about number 90987-02010 other numbers on this fuse are 7567000060. mine is on a 1993 Pickup. When i jump the connection together the truck runs fine.
Thanks
__________________
Ultimate Rides
402-750-7433
www.Iguanatrax.com
cweich is offline
Old 04-06-2007, 07:20 PM   #8 (permalink)
Quote:
i was just getting a bum connection... i dont see how this would fry my ecu??
david28 is offline
Old 04-06-2007, 07:23 PM   #9 (permalink)
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
Send a message via AIM to drguitarum2005
if he only wrapped ONE blade of the fuse with new metal, that won't harm anything. the fuse will still blow if there is a problem. now if he bridged the two blades with metal then yes, that would harm it.
__________________
-David
2000 Taco TRD Access Cab
v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights
Pictures
drguitarum2005 is offline
Old 04-07-2007, 10:51 AM   #10 (permalink)
yeah....its not bridging the fuse
david28 is offline
Old 04-07-2007, 10:55 AM   #11 (permalink)
TNRabbit's Avatar
ah. O K
__________________
TNRabbit
yotatech 3:16
Tags
130, 98, blow, box, clicking, efi, fuse, infinity, lexus, location, messed, relay, tacoma, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
efi fuse Sonofmayhem 86-95 Trucks & 4Runners 7 02-07-2007 09:02 PM
EFI Fuse wgomes 95.5-2004 Tacomas & 96-2002 4Runners 4 05-17-2006 02:20 PM
blown EFI fuse smudge122 95.5-2004 Tacomas & 96-2002 4Runners 2 01-24-2005 04:54 PM
Which Fuse Is The EFI Fuse? DiSperlonga 95.5-2004 Tacomas & 96-2002 4Runners 4 11-13-2004 08:52 PM
EFI Fuse Blowing... Churnd 95.5-2004 Tacomas & 96-2002 4Runners 5 05-18-2004 10:02 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
