ECU Diagram for 1988 3VZ-E - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-17-2010, 08:18 PM   #1
Challenga's Avatar
ECU Pinout Diagram for 1988 3VZ-E
Does anyone have a ECU diagram for a 1988 3vz-e 4runner? I have the 1988 Service Manual downloaded, but it is not in there. It's not in the Haynes either. Any ideas where I can find it? Apparently it is a legend. Mine is a 10/18/24 pin. I have looked through all of the manuals in the years around the 1988 and any cars that offered the 3VZ. I also google'd the heck out of it. No luck.....at all. I did however find a bunch of people looking for it. I just want the diagram of the plug, so I can do some backward testing. My engine won't start.
Challenga is offline   Reply With Quote
Old 07-18-2010, 06:15 AM   #2
krytellan's Avatar
Are you sure it's not there? There's a full pin diagram in the 90-95 manual.
krytellan is offline   Reply With Quote
Old 07-18-2010, 06:44 AM   #3
xxxtreme22r's Avatar
Don't know if this will help you out or not but here you go: http://www.yotatech.com/f116/3vze-ecu-pinout-88640/
xxxtreme22r is offline   Reply With Quote
Old 07-18-2010, 11:12 AM   #4
Challenga's Avatar
What I was hoping to find is a terminal layout like the one attached. Then I could just go through the terminal at the ECM and test back each wire. I'm having some issues. I did find a manual that has the map of the colors for each wire going in to the ECU, but was hoping to find a diagram like the one attached.
Old 07-18-2010, 12:33 PM   #5
MudHippy's Avatar
Quote:
Originally Posted by Challenga View Post
I did find a manual that has the map of the colors for each wire going in to the ECU...
Where'd you come across that?(I've got an 88 3VZE too.)
Edit: Found it! Nevermind. I didn't look too close at the thread mentioned earlier(post #3).
MudHippy is offline   Reply With Quote
Old 08-12-2010, 09:25 AM   #6
MudHippy's Avatar
EUREKA!!!
I have a super-human ability to find the internet gold nuggets. If it exists...I can find it. It was in an old thread here, of course. Not gonna say which one. Yall can find it on your own.
Viola!
The other tidbit from that thread.
keywords: 1988, 88, 4Runner, pickup, truck, 3vze, 3vz-e, 3vz, 3.0, 3.0L, V6, ECU, ECM, computer, 10/18/24 pin, pinout, diagram, pic, factory service manual, fsm, EFI
Old 12-05-2010, 06:48 PM   #7
Xeo
Xeo's Avatar
Don't mean to thread jack, but i have two 3vze ECU's sitting at home one says 3vze 4x4 A/T while the other just says 3vze 4x4 and thats it. Would the second ECU be for a manual truck? or will i never know? Reason im asking is because i intend to do a manual tranny swap for my 4runner and wanted to know if that ECU is for a manual truck. Thanks!
Xeo is offline   Reply With Quote
Need a quick identification on connector in radio area mct75 86-95 Trucks & 4Runners 8 08-22-2016 02:24 PM
WTB[FourCorners]: Ecu # 89661-3d361 Amer Items Wanted 0 09-15-2015 11:33 AM
Ecu Problem Dobich Newbie Tech Section 5 09-15-2015 12:15 AM
Installed e-locker, it doesnt work. ABS wiring related? Please help zz_denis 95.5-2004 Tacomas & 96-2002 4Runners 2 09-06-2015 04:43 PM
I want to swap 3rd gen 4runner transmissions bu need accurate wiring diagrams kelly1450 95.5-2004 Tacomas & 96-2002 4Runners 1 09-02-2015 01:29 PM
Tags
1988, 3v, 3vz, 3vze, 4runner, 88, diagram, drigram, ecm, ecu, engine, location, pinout, plug, toyota, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
