ebay h4 conversion kit installed - Page 11 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-05-2009, 09:51 AM   #251 (permalink)
Send a message via AIM to shaeff
Quote:
Originally Posted by stock as possible View Post
The vision plus aren't as good as the e-codes. E-codes have a much better lighting pattern. If you live somewhere where they will pay close attention to your headlights, get the vision plus, as they're DOT legal.
I have E-codes.
As for those of you wondering about the diode modification, it's to be used ONLY if you rewire your headlights using external relays, otherwise you'll burn out the diode, AND possibly fry your wiring in short order.
All you have to do, is on your rewire harness, jump the diode from your high beam switch (not the high beam power) to the low beam switch. The only current that the diode should be carrying is to power the relay for your low beams, NOT the current to actually power the headlight!
Also, it's best if you build your own harness, that way you can put the diode in the new male end headlight connector before it goes to your relays.
By the way, this is the connector that you'll want the diode in:
I've been running mine like this for a while, and have noticed no problems at all. However, if you do it incorrectly, you can really fry some wiring.
__________________
My heatercore replacement writeup with pics.
-'94 Toyota 4X4, 22re, 31X10.5 BFG M/T's, 5 speed, MC rear bumper. (Winter DD/ off road fun)
-'95 BMW M3, modded/suspension, sticky rubber, back road monster (Summer DD)
-86.5 Toyota Supra, too much to list. (Never-ending project)
shaeff is offline
Old 11-05-2009, 05:35 PM   #252 (permalink)
Robert m's Avatar
Quote:
Originally Posted by strykersd View Post
Looks good! Which kit did you use?
I'm selling my Hella 500s and converting my sealed beam headlights over to H4 HIDs. If that isn't enough I'll look into either Hella 4000s HID or Lightforce HIDs.
looks good? that light pattern is horrible! its beam cut off spread all over the place and the glare from it must be completely blinding to oncoming traffic. that is the exact reason you shouldnt put HIDs into non projector housings.
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd
Front: Total Chaos Uniball Kit, Downey Torsions, Fox 2.0 8'' Reservoir Shocks, Hannemann Fiberglass Fenders
Rear: Deaver F55 Leaf Springs, 9'' Total Chaos Shackles, Fox 2.0 14'' Reservoir Shocks, Custom Bed Cage, 4:10 gears & LSD
30x9.5 BFG AT Tires
Robert m is online now
Old 11-05-2009, 08:12 PM   #253 (permalink)
Staff
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
i've been very happy with the lights... i havent had anyone flash my yet.. the HIDs are a kit i sell..
__________________
94 4runenr: all the good stuff.......
89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs.
81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s
pacific-crawlers.com
For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :)
Tofer is offline
Tags
98, bosch, conversion, convertion, custom, ebay, glare, h4, kits, remove, rimiinc, shield, tippamm, toyota, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Weber 32/36 DGV conversion kit? -=j0nnyr0773n=- 84-85 Trucks & 4Runners 2 10-05-2008 07:27 PM
Tacoma 5-Speed Conversion Kit breknraj The Classifieds GraveYard 2 07-26-2007 02:58 PM
manual hub conversion kit TEPUI 95.5-2004 Tacomas & 96-2002 4Runners 4 04-12-2006 09:10 PM
is ors 3.4 conversion kit worth it? tuquoque 95.5-2004 Tacomas & 96-2002 4Runners 4 03-09-2004 01:03 PM
2009 InternetBrands, Inc.
