e-locker questions
Old 10-15-2010, 05:49 PM
GreenFlames's Avatar
e-locker questions
Howdy! I just picked up a E-locker out of a TRD tacoma for a very awesome price, and I had a few questions as in how I should go about installing it into my pickup, its a 1987 turbo pickup and it has 4.10 gears. How many things need to be modified in order to get the locker to work? I didn't get and wires or relays with the locker so I was wondering if I could just use any old switch that I have laying around. Any info on this would be awesome, thanks dudes!!
Old 10-15-2010, 06:36 PM
Teuf's Avatar
What gears are in the E locker?
Old 10-15-2010, 06:47 PM
I just have the locking mechanism itself and the actuator thing that's on the outside, I got it all for 150 bucks so I can't complain
Old 10-15-2010, 06:50 PM
Teuf's Avatar
OK great. What gears are in the E locker. Did I miss something?
Old 10-15-2010, 06:52 PM
It didn't come with the gears, I was just going to reuse the ones that are already in my truck if that's at all possible
Old 10-15-2010, 07:44 PM
nv4runner's Avatar
I haven't been inside an e-locker myself, but there is probably a part of the carrier that the gears attach to that slides to lock the diff together. Without that I don't think you can do the whole thing, but at least you don't have to look for one with the actuator motor included, which will reduce the price of the differential.
Old 10-15-2010, 07:53 PM
Robert m's Avatar
wiring harness and control kit
http://www.inchwormgear.com/store/index.php?cPath=25_62
how too links
http://www.4x4wire.com/toyota-tech/r...toyota-elocker
http://www.sonoransteel.com/phong/re...ic_locker.html
Old 10-15-2010, 08:27 PM
874runnersr5's Avatar
best bet is to buy gears that are made for the elocker and the setup elocker kit.
Old 10-15-2010, 08:44 PM
totally a bro
Staff
vital22re's Avatar
greenflames. Please search. There are a couple write ups on installing e locker thirds into non elocker housings from a different year. Its not just swap it out.
Old 10-19-2010, 06:27 AM
well i went back to where i got the locker and did some talking and i ended up with an entire TRD e-locker rear end for 200+tax, which isnt bad at all, they also refunded my 150 so really wasnt bad in the least, can i just replace my rear end with this one and run the wires to a switch in my dash? will that make it work all fine and dandy?
Old 10-19-2010, 04:10 PM
Robert m's Avatar
did you look at any of the links i posted above?
Old 10-19-2010, 04:57 PM
SpecialScottie's Avatar
x2
Old 10-20-2010, 05:33 AM
Yeah, I'm not paying 75 dollars for some wires and zip ties, I'll rig it up wire wise myself, I was just wanting to know if the rear end swap would be a bolt up swap or would I need to change some random things around.
Old 10-20-2010, 07:30 AM
Robert m's Avatar
just off the top of my head, the axle is wider so i dont know if the spring or shock mounts will be in the right spot. the brake hose connects on the opposite side of the 3rd, and the e-brake setup is totally different. now other then those things it might bolt right on.
Old 10-20-2010, 05:01 PM
well im going to pull off all the junk and stuff off the tacoma rear end and measure everything up right before i remove my rear end. so after that i will post my findings
Old 10-22-2010, 07:45 AM
alrighty, everthing lines up. now i was wondering about the wiring, i dont want to go buy a harness and all that jazz. What i would like to do it wire it up myself, anybody have any ideas on how this can be easily done?
Old 10-22-2010, 08:36 AM
here is a thought. correct me if im wrong (i probably am) could i just splice the green and green and red wires that go to the electric motor that locks and unlocks the locker into say...a window switch so when you put the "window" up it will activate the motor and lock the locker and when you stop pressing the switch it stops the motor but leaves the locker in the locked position, and when you put the "window" down it unlocks the locker? and i could hook the blue and yellow wire from the 2 pin connector to a light on my dash so i know when the locker is fully locked so i can know when to let go of the switch and vise versa. would this work or would i just break stuff?
Old 10-23-2010, 11:12 AM
ok, im feeling very lonely here. BUT i think i might have gotten somewhere, if i use a DPDT relay i should be able to get the electric motor to run forward and in reverse, im just stuck on wondering how i would attach a switch into this to make the circuit complete. Any ideas????? I would like to intergrate the window switch into this as well, but my wiring skills are limited.
Old 10-26-2010, 01:15 PM
cummins6speed's Avatar
You need the 3rd, member and gears inorder to use it. You wont be able to adapt your current gears or third member for the locking mechanism
Old 10-27-2010, 06:47 PM
I have the entire rear end
Quick Reply: e-locker questions
