Dumb sway bar problem
Old 06-03-2014, 10:30 AM
dromomaniac's Avatar
I just put new bushings on the sway bar, but the markings I made for the bar-to-frame bushings rubbed-off during the install. So, its not totally clear where the bar should be, in terms of left to right. Do I need to fret about this or just 'even' things out between sides and call it good? Just get the drops at right angles?
Really should have installed disconnects while in there.
edit: might as well post my other dumb question here, too. Bed mounting hardware: I have a pile of the mounting bolts (with the triangular-ish tabs at the head) that have come from several vehicles. Deal is, most of the bolts have a square piece of reinforced rubber as well as a washer and nut. A few have smallish (1/2"?) bushings. I don't remember ever seeing bushings on these guys except for body lifts. Ignore the bushings and proceed?
Old 06-03-2014, 11:16 AM
reallifedog's Avatar
yes, to everything you have asked.
Old 06-03-2014, 11:46 AM
chukarhunt's Avatar
^^^^ x2
Old 06-03-2014, 12:42 PM
Thanks! done and done.
Something about putting crap together in the dirt under the truck in >105 degrees seems to reduce my mental prowess. Better have a beer.
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
KBar
07-13-2015 06:01 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Dumb sway bar problem
