Dual O2??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-22-2008, 11:38 PM   #1 (permalink)
khoopes's Avatar
Dual O2???
Hi Folks, I am desperately trying to get my truck running to leave town. I am doing a Turbo engine swap in my 88 truck. The engine is out of an 87 turbo truck. I found out my truck had a dual oxygen sensor system and I am wondering what to do with the second O2 sensor now. Can the turbo computer even take a feed from the second sensor? I will have to do some fancy cutting and welding on the exhaust pipe to take the mounting plate area of the old exhaust pipe and splice it into the new pipe that does not have a place for the second sensor. Can I just unplug the second sensor and run without it?
Any help appreciated.
Kris
__________________
Kristopher Erik "KD5EJO"
Transplanted Alaskan in Foster OK
88 X-Cab now with 22RTE/93 FZJ80 Landcruiser w/e-lockers/"Work Truck" 00 Lexus LX470
FOR TOP NOTCH CARBURATOR OVERHAULS CLICK HERE http://www.yotatech.com/f37/ekhi-cus...turing-162085/
Like Fishing, hunting, Ham radio, flying, canoeing, kayaking, traveling, all the better with friends.
Dedicated Christian. Excellent Wife. 3 Very Good Sons. Any other questions?
khoopes is offline
Old 12-22-2008, 11:44 PM   #2 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
If the turbo truck didn't have the 2nd O2, I wouldn't worry about it. The 2nd O2 is basically to check on the catalytic converter operation. But, you may have some issues if you have to smog test it.
__________________
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 12-22-2008, 11:44 PM   #3 (permalink)
scuba's Avatar
Edit, Read that wrong...
__________________
Screw you guys I'm goin to TTORA
scuba is offline
Old 12-23-2008, 11:18 AM   #4 (permalink)
khoopes's Avatar
OK I found out it is not a second O2 it is the primary but it is in the tailpipe in front of the converter instead of in the manifold. It has a totally different plug though I will have to see if I can rewire the harness I guess.
__________________
khoopes is offline
Old 12-23-2008, 11:22 AM   #5 (permalink)
why not use the manifold from the turbo and keep the O2 up there and just leave the other O2 in the pipe to block the hole?
You are switching harnesses from the turbo onto the 88, right?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Going with a Flowmaster, should I go dual? fullcircle 95.5-2004 Tacomas & 96-2002 4Runners 10 10-12-2005 10:34 AM
Dual exaust wildmanchris 95.5-2004 Tacomas & 96-2002 4Runners 6 04-27-2005 11:00 PM
Do they make a dual? Jesters_taco 95.5-2004 Tacomas & 96-2002 4Runners 2 05-09-2004 01:16 PM
Dual Batteries Churnd 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2003 05:01 AM
2009 InternetBrands, Inc.
