YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 03-13-2013, 05:40 PM   #1 (permalink)
Personal Sales Rating: (0)
meswoleshane's Avatar
Lightbulb Dual battery swap pics
I just finished adding a second battery. Some of you might like to see it. I used a 135* bend off ebay along with a MAF cone adapter. Also went with a 200 amp continuous duty solenoid. Don't mind the battery hold downs, they are temp's till I can get some thicker ones made.
Click the image to open in full size.
meswoleshane is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-13-2013, 06:00 PM   #2 (permalink)
Personal Sales Rating: (2)
reaj's Avatar
Damn looks sick as hell, doing a dual set-up next week
__________________
1996 4runner SR5 (245,xxx)-New Motor (33,xxx)
- K&N Cold Air, NGK wires, TB Spacer, all blue hoses
- Drilled Rotors, SS BR lines, B&M 70268
- Shackled F&R, -40 cold start pack
- 2x Aux fuse Box, LED Swap
- A pillar Gauges, Reverse Gauges
- HIDs, Clear corners & Blinkers W/Mod
- Pioneer 3300BT W/ Backup cam & HD radio
- Kenwoods w/ Alpine 10" type R w/ Big 3
- Black Carpet W/ Black Husky liners
- CLD tiles, CCF and MLV sound proof!
Looking for someone to paint the truck in Denver!
reaj is offline
Old 03-13-2013, 06:07 PM   #3 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Nice job!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R-VP.
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
PACK IN, PACK OUT
'06 4Runner Sport 270/65R17 BFG AT's
Quote:
Originally Posted by kiyobrown View Post
funny, new parts get mentioned first, wife who has been gone mentioned second. Priorities, priorities. I like where your head is at.
BigBluePile is offline
Old 03-13-2013, 06:26 PM   #4 (permalink)
racersg's Avatar
Very nice. Well done. Does it run any different?
I have been wanting to do this exact same thing.
Congrats on job.
__________________
94 Pickup, 3 in BL, 2 in suspension lift. Manual w56, 22re, rebuilt with ported head and header. 8,000 Warn winch.
4:88 gears, Arb locker. M/T wheels, 33x12.50 tires.
racersg is offline
Old 03-14-2013, 04:59 AM   #5 (permalink)
87blackbeauty's Avatar
Rich Wilson
Why the solenoid? I thought you could just hook the batteries straight together.
87blackbeauty is offline
Old 03-14-2013, 05:19 AM   #6 (permalink)
irab88's Avatar
Location: Maryland Occupation: Classified Mileage: 207K
ianrab
Send a message via Yahoo to irab88
Quote:
because if you leave your lights on, you won't be able to start your truck if you wire them straight together. with a solenoid, you can drain one battery completely and still start using the other one. (there are other reasons, but that's a good example)
also, @meswoleshane: do you have a schematic of your setup (ie, where each battery hooks to the starter, alternator, fuse box, etc). i really like the clean look you've got going there
__________________
--Ian
I'm not going slow; I'm just enjoying the trail...
93 PickUp DLX, 22RE-C, 4x4
Build Thread: the Red Rover |Last »|
135
R151F, 2.28 & 4.7 ╠╬╣
24R
LL4
RADesigns Shifters ║║║
HH2
(my trailer build)
(my boat build)
irab88 is offline
Old 03-14-2013, 06:42 AM   #7 (permalink)
Threadstarter [OP]
racersg, It runs about the same, maybe the rear window works faster? I have an amp, a few aux lights and 12V outlets. I plan on adding a winch in the future as well. I did this mostly for camping, this way I don't have to worry about the air matress pump or 12V fan killing the starting battery.
irab88, Here is the wiring diagram:
http://www.expeditionportal.com/foru...y-setup-for-50
Old 03-23-2013, 05:08 AM   #8 (permalink)
bone collector's Avatar
subscribed thanks for the great pictures and link!
__________________
79 - 224 4x4 4 sp--scrapped
87 - 22r 4x4 31" bf goodrich MT - sold
94 - 3vze ext cab 32" goodyear wranglers
7mge coil, 7mge afm, 2.5 inch ISR, 8 mm wires
1200lb marlin crawler HD clutch, EGR/Pair Delete
93- parts truck. hole in the block 3.0.
91 fj80 land cruiser - 4.0L inline 6, grocery getter weekend camper, 4x4
Build thread http://www.yotatech.com/f199/bone-co...thread-258959/
Proud owner of the PHAT farm ......
bone collector is offline
Old 03-23-2013, 05:19 AM   #9 (permalink)
ThatGuy1295's Avatar
ThatGuy1295 is offline
Old 03-23-2013, 05:24 AM   #10 (permalink)
Threadstarter [OP]
Quote:
Originally Posted by ThatGuy1295 View Post
That looks good. Did you have to relocate anything or was there enough room for the extra battery?
Old 03-24-2013, 07:10 AM   #11 (permalink)
Quote:
Had to relocate the cruise control closer to the air box. But not to hard to move. My taco doesnt have abs. If it did there would be no way this would fit. And my lights shut of automatically so no need for solinoids or isolators
Old 03-24-2013, 09:29 AM   #12 (permalink)
TylerH's Avatar
Send a message via MSN to TylerH Send a message via Yahoo to TylerH
Im a little new to this whole thing but wouldnt two batterys wired together cause double the cranking amps which could pop fuses or fuseable links. Other then haveing a winch or a huge sound system why would you need to do this?
I know toyotas have pretty low amp alternators but if your driving it shouldnt matter
I have four aux. lights wired with two relays and i see no change in anything other then at idle?
Plz explain.
__________________
1992 Toyota 4x4 Deluxe (no options)
Custom bumpers, HELLA 700FF's, Aluminum box, Four Runner bucket seats and Center console, Reman 22re 0 miles as of now, NWOR header and flowmaster.
Did the ricer thing... that got old. Did the GF thing, that got old. Toyota time....
TylerH is offline
Old 03-24-2013, 10:03 AM   #13 (permalink)
Yes it doubles the cranking amps. But thats ok because starters and all other electronics only use what they need. You can never have to much Cranking Amps.
And the reseon for running 2 batteries in parallel like that is becuase it doubles the capacity for power. Its simple and effective. The only thing is you should always use the same size and age battery when paralleling.
I could parellel 5,000 12v batteries together and still start a car. Look at solar homes, their tv doesnt explode if their battery bank is to big.
And actually more damage will occur from under powering winches and starters.
Old 03-24-2013, 10:12 AM   #14 (permalink)
Their are many reseons for going with both types.
If you run 2 batteries with an isolator, you can run one battery until its dead and still start your car. But you only have 1 batteries worth of juice for running stuff with the motor off.
If your not worried about being able to start your vehicle, or it doesnt matter becuase the inverter your using shuts off before the battery is depleted beyond the ablility to start a vehicle. Then it would benefit you more to run the batteries in parallel. Now you have 2 batteries worth of power when running stuff with the motor off.
Old 03-31-2013, 07:07 PM   #15 (permalink)
matt18603's Avatar
Andronicus666
Dual battery setup with an isolator is next for me. I just installed a loadboss 170 amp alternator and a bigger battery. My plans are another set of lights, an inverter, and an amp. I already have a cb and stereo of course but Id like to add a scanner. My question is this....I read in a forum online that the batteries should be the same, is that true? Doesnt make sense to me. I planned on my secondary (accessory battery) to be a bit smaller. You see a problem with that? Thanks.
matt18603 is offline
Old 03-31-2013, 07:16 PM   #16 (permalink)
Threadstarter [OP]
Quote:
My understanding is that the batteries will drain each other down when left connected if they are different. That is the purpose of the solenoid. My second battery is actually bigger than my starting battery (I had it already). I have had no problems with this.
Old 03-31-2013, 07:34 PM   #17 (permalink)
Mr Duke's Avatar
Any difference in temps or performance with the relocated and angled intake pipe? Having an idea for this with my 3vze
__________________
Eric from Memphis, TN
1989 Toyota pickup Xtra stock...with plans!
Mr Duke is offline
Old 03-31-2013, 08:05 PM   #18 (permalink)
Threadstarter [OP]
Quote:
Nothing noticeable. I would guess the intake temperature would be lower this way (not going across the radiator or engine bay). It is also in a higher position than the stock box.
Old 03-31-2013, 10:00 PM   #19 (permalink)
Ideally same voltage, capacity and charge state when parallel charging. The solar guys go so far as to not even mix batteries from seperate manufacturing lots. Here is a decent link I think sums it up well.
__________________
Co_94_PU is offline
Old 04-01-2013, 07:58 AM   #20 (permalink)
Staff
aviator's Avatar
Sort of off topic but going through the links above I found a source in Dallas TX for HO alternators for the 3.0 v6 http://storesense1.mysuperpageshosti...ail.bok?no=520
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported AFM, adv. timing, 2.5" exhaust, free flow cat, Magnaflow muffler
custom covered SR5 seats, custom factory center console, map lights, AC, Aisins
tv4184 style black interior conversion started
mods to come... header,
custom carpet, stereo upgrade
tinted windows
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
3vze, battery, dual, tech, yota, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
