Driving RPMs Too High ?
Driving RPMs Too High/Code 64 ?
Vehicle: 92' 4Runner, 3.0 4x4 A340H, 202Kmi rolling on 31x10.50R15 A/Ts, stock gearing. Headgasket, waterpump, Thermostat, Timing Belt done @ 182K. I purchased the rig back in late July from a local Mechanic/Shop owner, This is my first 4runner as I upgraded from a Jeep XJ.
My Issues:
At 65MPH with O/D on the truck is running right at or a hair under 3K RPMS
At 65MPH without O/D on the truck is running right at or a hair under 4K RPMS
Recently my OD light began to flash a Code 64, I took it to a family friend whom was in the Transmission Business for 30 years. We both took the rig for a drive test around town & on freeway, the A340 shifts Fine and hits all its shift points & has never had any issues shifting into OD. Stall speed is around 2700RPMS which is normal from what I've been told.
My Question: Is 3K RPMs @ 65 with OD on normal for 4runners ? (I'm used to my Exploders & XJs to be from 1800-2300 @ 65.) What would bring these RPMs up & why would I be getting a Code 64 is nothing is mechanically or electrically wrong w/ my Trans ?
My Issues:
I told the mechanic 3grand is just getting into powerband but took his advice & figured I'd ask here to be on the safe side. Now I just have to figure out WTF is up w/ that Code 64 if nothing is actually wrong.
I also recently "upgraded" from a 1998 XJ which I totalled and am driving a 2nd gen 4runner with the 3VZE now..
Within a week of owning the 4runner I was trying to figure out how the hell I could swap in a H.O. AMC straight six/AW4/NP242 combo. Now I've just gotten used to the high RPM's, getting passed by grandmothers on their way to church, the terrible gas mileage (even compared to a Jeep!) and the tinfoil body panels. It's a toyota thing, I understand
Truth be told, the Toyota does feel like a solid vehicle but I think it'll take some time to get used to the power difference between the AMC straight six and the 3VZE
Last edited by jbw; 11-18-2010 at 04:59 PM. Reason: edited to gripe about the horrible gas mileage too!
My 3VZE seems to purr at 4k on the highway. My speedo is busted, so I think I'm hitting around 120-130km/h. It's done many 8hr stretches at those revs, up and down some hilly highways, with no problems. Transmission gets a little warm through the floorboards (5spd), and the engine burns a bit of oil... but I love it.
i am also new here, i have a 94 3.0 vze engine i think, with 31"s and im going 65mph but my rpms going at about 3200 is that normal? it has a 5sp manual tranny 4x4. Im concerned please help
Thanks for the reply, I'm concerned of high rpms because i know my engine need some work, it suffers form that famous lifter noise these engines make.SHould i try and keep her under 65 mph because of the lifter noise?
also what tire size u put in your 4runner? and did it need to be lifted for them to fit?
I love the 4runner just think i should have gotten one with a 3.4
I have a 22re with 4.88's and 31 inch tires and I run 3K to 3.5K on the highway. Since re-gearing and adding the tires plus adding a V-6 Sr5 cluster I do not know my exact speed. Doesn't seem to be winding out at all though.
ZONAYODA
07-13-2015 07:17 PM
Poncho0206
07-10-2015 06:21 PM
Jnkml
07-06-2015 01:20 PM
