driveline vibration
Old 11-17-2009, 03:20 PM
OnePunk's Avatar
driveline vibration
So i have a bone stock 92 4runner 3.slow 5speed 4wheel drive just clicked 220,800miles on it this week and about a week ago i noticed a slight vibration when accelerating, now its vibrating alot more when i accelrate and is really bad when decelerating, i dont think its happening at cruising speeds. i also recently learned the previous owner wasnt exactly "easy" on it. I know its not imbalanced wheels, warped rotors or a bad steering stabilizer. I feel nothing in the steering wheel, nothing when i hit the brakes, just when i accel and decel its a very noticable shudder, it makes my rearview go blury from shaking. I have a feeling its a carrier bearing or u-joint, thoughts?
Old 11-17-2009, 03:55 PM
yoterr's Avatar
def sounds like carrier or u joints, pull ur D shaft n rotate it around, see if theres any hard spots..
Old 11-17-2009, 04:06 PM
wilshire's Avatar
Remove the rear driveshaft and put it in 4 wheel drive and drive it around a little. That will either confirm or rule that out. It sounds more like something in your differential, but checking the driveshaft like that is easy and free.
Old 11-17-2009, 04:10 PM
Master_Yota's Avatar
just keep driveshaft in and check for slop in ujoints. put in nuetral though.
Old 11-18-2009, 02:12 PM
OnePunk's Avatar
can you be more specific? should i jack it up? rotate the driveshaft or just try to move it back and forth?
Old 11-18-2009, 05:39 PM
what he said but get NAPA ujoints. theyre good and wont go bad for sure.
Old 11-18-2009, 05:53 PM
93YotaMonster's Avatar
like every one else said it probably a u joint.
Old 11-19-2009, 02:40 PM
OnePunk's Avatar
yup, as suspected, there is quite a bit of play in the front, a tiny bit of play on the rear, guess ill just replace them both to be on the safe side.
Old 12-14-2009, 06:02 AM
JollyGreen's Avatar
do you just grab the driveshaft with your hand and push / pull it to check, or do you use a prybar or something?
My 94 truck has a vibration from 15-20 mph regardless of gear / motor rpm etc..
it has been getting worse recently and it is time to track it down.
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: driveline vibration
