Drive Shaft Tube Size
Old 09-20-2010, 05:11 PM
DanStew's Avatar
I need to lengthen my front shaft a bit. Is there a tubing size that will work from the metal supply, or will I have to get the inside machined down to fit the yoke/splines into it?
Thanks
Old 09-20-2010, 05:15 PM
xxxtreme22r's Avatar
Can you use a spacer available on the 4crawler site or do they not work for front shafts and only work on the rear?
Old 09-20-2010, 05:25 PM
waskillywabbit's Avatar
Its metric size tubing iirc but you can use standard size stuff if you machine it. I never mess with it I always just take it to my diff/driveshaft guy and let him mess with it.
:wabbit2:
Old 09-20-2010, 05:53 PM
DanStew's Avatar
Thanks I was wondering if it was metric. probably could have guessed since it was Japan, but worth a shot.
Thanks
A2theK
01-10-2016 10:18 AM
09-04-2015 09:27 AM
adammtb
07-27-2015 11:57 AM
andrewtexas123
07-14-2015 04:29 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: Drive Shaft Tube Size
