Drive Shaft Maintenance diagram - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 12-02-2007, 01:59 AM   #1
strykersd's Avatar
My 86 4runner came with a small how to diagram for lubricating the drive shafts in the driver side visor. After 21 years the hard paper has cracked in many places. I was wondering if someone who still has one in decent condition could pull it out and scan it for me. That way I could just print out a new one. Thanks
strykersd is offline   Reply With Quote
Old 12-02-2007, 06:15 AM   #2
TORTIS's Avatar
Quote:
i never knew such a diagram existed.
TORTIS is offline   Reply With Quote
Old 12-02-2007, 06:24 AM   #3
bigt's Avatar
wish i had a scanner hahaha i could take apicture or send you one i have 2
bigt is offline   Reply With Quote
Old 12-02-2007, 02:29 PM   #4
leebee's Avatar
check the link at the top of the page for the fsm, look in the drive line section. there should be a diagram located there.
lee
leebee is offline   Reply With Quote
Old 12-02-2007, 03:08 PM   #5
MMA_Alex's Avatar
i have it somewhere....I'll have to look around...probably tucked into the manual. mine is laminated though so i'm not sure if its the same thing you're looking for?
MMA_Alex is offline   Reply With Quote
Wiring help toyotamonster 3.4 Swaps 6 12-30-2016 05:38 PM
FS[PacNorWest]: Rear chromoly axle shafts A2theK Axles - Suspensions - Tires - Wheels 5 01-10-2016 11:18 AM
Leaking Rear Tranny Seal and Top Tranny Gasket Iceman4193 86-95 Trucks & 4Runners 3 07-15-2015 05:48 PM
Leaking extention housing seal andrewtexas123 86-95 Trucks & 4Runners 3 07-14-2015 05:29 AM
1988 pickup oil pressure gauge wiring HELP! 88yodabasket 86-95 Trucks & 4Runners 15 07-13-2015 02:32 PM
Tags
2000, 2002, cv, diagram, drive, driveshaft, f150, half, kirby, maintenance, mkv, rear, runner, shaft, toyota, train, yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
