Drive Shaft issues
Drive Shaft issues
I have a 1990 pickup with the 63" chevy spring swap in the rear. I love it, but my rear drive shaft is literally hanging on by about 1/8 inch. With the vehicle on the ground the total length of it should be just under 48". So I went to the local scrap yard and picked up a 47 3/4" long drive shaft off a 96 4 Runner and it looked like it had the same 4 bolts in a square pattern as the one on my truck, but when i got it home and all hooked up i noticed that one end was slightly larger than I needed it to be.
The last pic just shows how much the bolts are off by.
Is there some kind of fix i can do, i.e. swap out the u joints, or just drill/open the holes to accommodate the larger patter? I am kind of new to off-roading, so any help is greatly appreciated.
Pic 1: http://imgur.com/6IKXL (The link incase the pic didn't work)
Pic 2: http://imgur.com/b3snH
You can't swap the u-joint flanges between the driveshafts because the double cardan u-joints are slightly smaller than the type that fits all the other driveshaft yokes. Other than that, you could(you usually can if it's not a CV/double cardan joint). The only thing you can do to make it work is rotate the driveshaft 45°-90° from the original holes and drill new holes in the transfer case/pinion flange.
Or spend $40 on one of these triple drilled flanges.
http://www.marlincrawler.com/differe...rential-flange
Sweet that looks like it'll be the solution. Hmmm $40 bucks and a quick swap, or pain in the a#$ drilling? Not a tough choice there. Thanks a ton Mudhippy and everyone else.
Uh oh...
I hope I didn't just point you in the wrong direction. Maybe you haven't ordered it yet. Or maybe you figured this out on your own. Or maybe you want a differential flange and not a transfer case flange(for whatever reason, less holes but cheaper maybe?). I don't know, but I might have screwed you up. Depending on what your situation is. As in which type of transfer case output shaft you have(gear drive: 27 spline vs. chain drive: 30 spline). Because you have a driveshaft with the 4 cyl. bolt pattern I figured you had a 4 cyl. transfer case, which are almost always gear drive(and use a 27 spline flange just like all 8" differentials do). But I happen to know(first hand, seen it myself) that the 4 cyl bolt hole pattern has been found before on V6(chain drive) t-case output shafts(which have 30 splines, and can't be swapped with 8" differential flanges). And you can also upgrade a gear drive t-case to a 30 spline rear output shaft(don't know if you've done that either).
This triple drilled flange is for differentials specifically. But it should also work with any 27 spline t-case output shaft. The only difference would be the dust sheild...AFAIK.
This is the 27 spline quintuple drilled transfer case flange(notice the different dust sheild).
http://www.marlincrawler.com/axle/dr...-spline-flange
Chain drive transfer cases have 30 spline output shafts though. So they make a quadruple drilled transfer case flange for those. The output shafts on chain drive t-cases also use a small internal oil seal(under the nut) that gear drive t-cases don't...AFAIK.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
