Drive-ability
Old 08-09-2011, 06:02 AM
dktool's Avatar
Drive-ability
I recently completed a engine rebuild on my 91' 3.0 Auto 4Runner 4x4
It runs great, passed smog check with ease, all vacuum line, sensors, emissions components are correctly installed / connected.
This is my question:
When driving or even just working the throttle by hand, there is a dead spot between 1500 and 2000 RPM.
It will throttle down smoothly until it reaches 2000 and then with a little more closing of the butterfly it will instantly drop to 1500 RPM and conversely when accelerating.
Does this sound like a Throttle Position Sensor issue or ??
Has anyone experienced the same thing ?
Old 08-09-2011, 06:34 AM
skypilot's Avatar
Could be VAFM with a flat spot too.
Old 08-09-2011, 06:42 AM
TNRabbit's Avatar
or Throttle Position Sensor.
Or worn butterfly valve in the throttle body.
Old 08-09-2011, 06:43 AM
dktool's Avatar
Is the TPS normally located about midway in the mounting slots ?
I noticed that mine is adjusted almost all the way to one end of the slot.
Old 08-09-2011, 12:39 PM
TNRabbit's Avatar
You need to search here for "TPS adjust"....it's a little complicated.
Old 08-09-2011, 06:02 PM
dktool's Avatar
I did a search as suggested and found:
http://www.4crawler.com/4x4/CheapTri...roubleshooting
Good read, went through it and checked and adjusted the TPS and the issue is gone.
It also reduced the automatic shift points which did seem high to me.
When I was finished, the TPS was about as close to centered in the adjustment slots as it would be if eye-balled.
Thanks for the help, now its on to suspension mods.
If anyone has a good direction to point me in on the road to articulation improvements feel free to point.
Loose the rear track bar and sway bar perhaps ??
Old 08-09-2011, 07:35 PM
sc87yota's Avatar
Removing the track bar would be a bad idea. Removing sway bars will be better for offroad but worse on the street. In my experience leave the IFS stock and save your $ for a solid axle if you want flex.
Old 08-09-2011, 08:09 PM
dktool's Avatar
SC87,
How did your BJ spacers and 2" springs work out, is it mostly for looks or does it really make a worthwhile improvement for off road ?
Old 08-09-2011, 08:42 PM
sc87yota's Avatar
Honestly... IT LOOKS GREAT! haha. In my opinion it does not perform much better than stock. There is more room for bigger tires which is nice but I have already purchased a solid axle and have future plans for it. I have replaced EVERYTHING in my IFS system and still want and expect more out of it(lil' frustrating) The most "worth while off-road improvements" I have done would be lower differential gears and manual hubs. The best modification you could probably do for 4x4 purposes is a locker! My advice is to use this forum and learn from other peoples experiences so you dont flush money down the toilet.
Old 08-09-2011, 08:43 PM
sc87yota's Avatar
Originally Posted by dktool
SC87,
If you have time check out my build thread https://www.yotatech.com/forums/f199...thread-229879/
Old 08-10-2011, 05:17 AM
dktool's Avatar
I hear ya, I recently installed a Aussie Locker in the front of my 95' Jeep YJ and it made a huge improvement.
I found a new Aussie for sale locally on Craigslist for this 4Runner, I my grab it, they do work good.
Old 08-10-2011, 06:33 AM
sc87yota's Avatar
... Sell the Heep and put it into your 4runner
usmma2013
Diesel Swaps
34
09-25-2018 12:01 PM
farmkid4
10
02-09-2015 05:38 PM
AdmiralYoda
07-25-2013 05:06 AM
snobdds
06-10-2013 06:39 PM
Quick Reply: Drive-ability
