Drilled out oil pressure sender - Need help
Old 12-03-2012, 04:31 PM
rbig18's Avatar
Been on here a few weeks reading up as I work on my 86 runner (22RE-C). All kinds of things been done in last weeks and will share later but right now I have an issue.
Started to mount an oil pressure dial and the old sender unit would not come out. Easy outs, reverse drills etc and days later still stuck in there. So tonight I drilled it out with a 3/8's bit and will convert to NPT. I am very worried about the shavings however. I have seen conflicting reports on the oil flow and if these will get picked up by the filter or not. Need help from those that have done this. Best way to get these out? Thank you
Old 12-04-2012, 03:14 AM
Pat8942's Avatar
Pull the coil wire, crank the motor till some oil comes out the hole and the shavings will come out with the oil.
bigjstang
08-25-2021 12:41 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: Drilled out oil pressure sender - Need help
