Drain block of antifreez to drain heads - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-19-2006, 07:22 PM   #1 (permalink)
I am taking the heads off of my 3.0 and am wondering if there are any drains on the block. From past experience it seems when you pull the heads a bunch of antifreeze gets in the cylinders.
__________________
91 4runner SR5 V 6 3.0 190,000 5 speed 32 x 10.5 Manual Hubs Otoe County Nebraska
jjenks0 is offline
Old 04-19-2006, 07:35 PM   #2 (permalink)
Here you go.
PhiHalcyon is offline
Old 04-21-2006, 09:52 AM   #3 (permalink)
Radyota's Avatar
I drained the radiator, then pulled off the lower rad hose and thermostat/housing. Also pulled off the little hose on the right side of the thermostat/water pump that goes to the oil cooler and lowered it to drain the block. I got absolutely no antifreeze in the cylinders when I pulled my heads off.
__________________
'92 toyota Xtracab 4x4 pickup-3.0 v6,5 speed, 235/75 15" tires, intake "Y" hose and associated vacuum boxes eliminated,186,000 mi., engine almost together,Engnbldr's grade 10.9 head bolts, clutch now replaced w/Centerforce dual friction clutch.
'84 toyota Supra P-type 5MGE inline 6, 5 speed, 179,000 miles, RWD Ltd. slip, Pacesetter header, 5 slot mags and NO muffler.
Radyota is offline
Old 04-21-2006, 07:57 PM   #4 (permalink)
Send a message via AIM to miket223 Send a message via Yahoo to miket223
Good luck getting to those block drain plugs with the engine mounts bolted to the block.
miket223 is offline
Old 04-21-2006, 08:24 PM   #5 (permalink)
Thanks for all of the suggestions
__________________
jjenks0 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Pics of 3VZ-E block coolant drain bolt(s)? brjason 86-95 Trucks & 4Runners 1 02-04-2007 02:57 PM
Anybody got a pic of where the drain plug is for the block? vmax84 86-95 Trucks & 4Runners 26 03-18-2006 02:36 PM
new drain plug Localmotion Off Topic Talk 2 12-11-2005 12:47 PM
Where's the block drain plugs? PY Maintenance & Repair Archives 1 08-11-2004 08:29 AM
Coolant drain on a 2.7l block? Please help. Foch Maintenance & Repair Archives 3 06-09-2004 12:00 PM
2009 InternetBrands, Inc.
