Door won't open on '94 4Runner
Old 10-03-2006, 11:50 AM
AR4Runner's Avatar
Hi, my drivers side door is stuck on my 1994 4Runner. We've got the door panel partially pulled back and can see a vertical rod that should be on a red plastic piece. We can't get that rod back on because the door won't open and we can't to get to it. We can't release the latch to open the door either. It will lock and unlock but it stays locked. Um, by the way, I'm the wife - can you tell????
Old 10-03-2006, 02:20 PM
AR4Runner's Avatar
Please somebody help me:cry:
Old 10-03-2006, 02:24 PM
snap-on's Avatar
im confused... the door is locked... and wont unlock?
or the door handle rod to actuate the release is "not functioning"
if i remember right... the inside handle, inside lock button are all independant of the key lock and outside door handle... so if anyone of them isnt working you have another chance at getting the door open.
Old 10-03-2006, 03:04 PM
AR4Runner's Avatar
Yes, that's it! The door is locked and won't unlock. I've never had trouble with it before until someone locked it with the key and whatever happened and now my door won't open....
Old 10-03-2006, 03:07 PM
snap-on's Avatar
so neither the key or the lock button inside work?
Old 10-03-2006, 03:17 PM
AR4Runner's Avatar
Neither one.
Old 10-03-2006, 03:34 PM
Pozi's Avatar
When lifting or depressing the lock on the door does it feel like it engauges or dis-engauges the locking mechanism? Sounds like something came off inside the door. You may have to take off the door panel and investigate.
Old 10-03-2006, 04:08 PM
Dublin's Avatar
The problem with taking the door panel off while closed is the last few clips obscured by the dash. If you don't mind panel carnage by all means yank it off, it'll never be the same. Your best bet seeing neither inner or outer lock and latch is working is one of the following with access to a slim jim: Local law inforcement, body shop, stealership or someone that has one (perferably someone not into jacking cars).
Old 10-04-2006, 07:26 AM
AR4Runner's Avatar
Thanks for all the good advice, we have done everything that has been suggested to no avail....We took it to the mechanic this morning. Let's just pray it won't be $$$$$$
Old 10-04-2006, 03:41 PM
bballchrism's Avatar
just go the dukes of hazards way
Old 10-04-2006, 06:05 PM
doc76239's Avatar
I second the dukes of hazard way.
Old 10-04-2006, 07:27 PM
AR4Runner's Avatar
Oh yes, the lady in the skirt hopping out her drivers side window at the office. Nicccceee. Not. Got the news today, $300 parts & labor.
Old 10-05-2006, 02:02 PM
leebee's Avatar
is it a small spring on the latch mechanism that broke? from what you are describing, that is the problem i experienced a while back. i rigged up a pull wire to actuate the mechanism until i was able to get a new spring. ill try and attach a pic of the offending little beastie.
Attached Thumbnails Door won't open on '94 4Runner-doorlock-springa.jpg   Door won't open on '94 4Runner-doorlock-springc.jpg
Old 10-15-2006, 06:25 PM
AR4Runner's Avatar
Yup, that was it!
Old 10-15-2006, 07:18 PM
95RunnerSR5's Avatar
eventhough you found the prob...x3 on the dukes...couldn't resist sorry
06-01-2021 01:51 PM
Cplmike
07-08-2015 08:47 PM
raiderhawks00
07-08-2015 06:23 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Door won't open on '94 4Runner
