Door slide please help
The pin for the door slider thing inside the door jam between the 2 hinges fell out when I closed the door and I think the sliding arm itself fell back inside the door is there a way to get it or if not how much would a new one be and what is it called
You should be able to pull the door panel and fish it out with a magnet.
I think it is called the door Check but I am not really sure
Someone on here or at a yard close to you should have one.
I know i have one if your really stuck
The only thing it really does is keep the door from opening to far that the door gets kinked at the hinges
The pin alone is not too expensive
http://www.toyotapartsoverstock.com/...861720011.html
But the whole door check is about $70. Making it worth fishing out of the door.
Disassembling the door is not too hard. https://www.yotatech.com/forums/f116...t-work-254772/
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
Odin
09-26-2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
