door hinge?
door hinge?
i have a 91 xtra cab 4x4. i need to replace my driver side bottom door hinge. does anyone one know if an older model hinge would work? or what is the years that would fit?
89-95 hinges. Side note, there is only two different hinges for the doors. The upper hinges are simply flipped and reversed to go on the lower.
I just got used upper hinges and replaced my bad lowers..
You can find new door hinges at www.partstrain.com there under 12.00 dollars each.
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
Odin
09-26-2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
